944 Heater Clip
Has thanked: 944 times
Been thanked: 4034 times
Trust you know you don't need to remove the core to put the clip on. ;) But if you need to remove it, here's a link to our very detailed dash removal write-up.
viewtopic.php?t=341
#41
Anesthetic
Nice work
#42
iotsl00
Tom wrote: Sat Jan 15, 2022 4:20 pm Here is a 3D-print STL file for the notorious 944 heater clip, and a video showing how it works. When these break, which they do often, the car has nothing but hot air from the vents. Super fun in the summer. There are two STL files below, one for the main clip, and one for the helper 'spring' that keeps it tight. The second piece is optional, but better safe than sorry. :)
944 heater clip from carpokes.stl
944 heater clip clip.stl
niiiiceee
#43
Serpentine
Excellent
#44
Entopy
#45
Roo
I especially like the optional clip. A better design than the original
#46
seltzdesign
Has thanked: 7 times
Roo wrote: Sat Feb 22, 2025 9:58 am I especially like the optional clip. A better design than the original
The originals and the replacement ones you can buy come with a metal clip on them. Too bad the plastic they used wasn't designed to last that long.
I got these before and they work great: https://transaxleworld.de/produkt/heizu ... he-944-968
But I actually need some more and will just use the 3D print version.
Thanks to OP for the video and files!
#47
BenMaybery
Brilliant, saved me lots of time.
#48
CR_1
Thank you for this. Very helpful.
#49
Excorcist
Thank you so much, this is amazing.
#50
