3.0 16V engine mods, etc
- chris white
- Been thanked: 175 times
I tossed my Spec clutch after one day. Gotta be pretty bad to go through a second clutch job right away!!!
- Has thanked: 943 times
- Been thanked: 4028 times
I'm much lazier than you, and was gullible enough to listen to the seller who swore it would smooth out after broken in. It didn't!chris white wrote: Sat Dec 07, 2024 12:53 pm I tossed my Spec clutch after one day. Gotta be pretty bad to go through a second clutch job right away!!!
- Thom
- The First Carpoke!
- Has thanked: 138 times
- Been thanked: 153 times
Thanks all for your feedback on Spec clutches. I was already looking into some of these in case my issue was deeper than reported but I'm glad I don't seem to have to go further (touch wood again with 4 leaf clovers all over the place and praying the clutch gods).
After further thinking I do believe that the issue was caused nothing more by not loosening the rod after fitting the strut tower reinforcement.
I'm so so glad I can enjoy my 944t to its fullest again. I just can't live anymore without experiencing traction loss at 100 mph every once in a while.
'90 944 turbo
"I'm so so glad I can enjoy my 944t to its fullest again. I just can't live anymore without experiencing traction loss at 100 mph every once in a while." Lolssss....I know the feeling...no really....
- Thom
Perfect. If it wouldn't make you nervous a little then what's the point of such projects. Flooring it at "high" speed on slippery roads takes some confidence but with a talkative chassis and big brakes it is impossible not to want to keep trying and enjoy the adrenalin rush. It never rains in Straya so what are you worried about anyway
'90 944 turbo
Haha true and when it rains the cars stays inside. The problem here is the oil on the road builds up so much when it's dry, the road turns to ice even on light rain.
I'm sure between the LSD and the traction control I should be ok.
Thom wrote: Mon Dec 09, 2024 6:49 am Perfect. If it wouldn't make you nervous a little then what's the point of such projects. Flooring it at "high" speed on slippery roads takes some confidence but with a talkative chassis and big brakes it is impossible not to want to keep trying and enjoy the adrenalin rush. It never rains in Straya so what are you worried about anyway![]()
What TC are you going with?Bergerac wrote: Tue Dec 10, 2024 1:09 am Haha true and when it rains the cars stays inside. The problem here is the oil on the road builds up so much when it's dry, the road turns to ice even on light rain.
Hooked up the ABS sensors to the Link.333pg333 wrote: Tue Dec 10, 2024 2:46 amWhat TC are you going with?Bergerac wrote: Tue Dec 10, 2024 1:09 am Haha true and when it rains the cars stays inside. The problem here is the oil on the road builds up so much when it's dry, the road turns to ice even on light rain.
