Slow to spool
Been thanked: 4080 times
Spencan wrote: Sun Nov 05, 2023 1:45 pm Just an update on my “slow to spool” situation. I found my culprit to the flange that connects 90* elbow pipe to the wastegate was not tightened all of the way; IMG_2723.jpegI was able to unscrew the three nuts/bolts with my hand! So, I put lock washers on both ends and tightened them, and problem solved!
Looks like those bolts are drilled for safety wire too -- might be worth adding the wire. I'm wondering it those adapter plates lend themselves to loose bolts, causing someone to drill them originally?
#21
michaelmount123 wrote: Sun Nov 05, 2023 1:56 pm Nice work, and a lesson to all with a similar spooling issue. Check all the simple things first!
That's universally good advice that applies well beyond car repairs. :)
#22
notny41
Has thanked: 31 times
Been thanked: 51 times
Wow! that is awesome!!!
#23
Spencan
Has thanked: 132 times
Been thanked: 32 times
Tom wrote: Sun Nov 05, 2023 2:06 pm
They weren't the bolts on the adapter plates, they were the 3 that connect the pipe to the exhaust, the other end. You are right Tom, I should and will go back and add the safety wires to the adapter plate bolts.
#24
I always use mechanical locking nuts on that connection. I probably have 3 spares if you need them. :)
#25
onspeed
Been thanked: 5 times
Is it normal on the 2pc crossover to have a tiny amount of play at the flange going to the wastegate ? The 3 bolt triangular flange that uses a metal donut to seal.
#26
Spencan
That’s what I tightened so that there’s no play/leaks…
#27
onspeed
Spencan wrote: Wed Nov 08, 2023 8:20 pm That’s what I tightened so that there’s no play/leaks…
So you have ZERO play at that joint? Maybe my sealing donut needs replacing
#28
