Throttle Body Options
gruhsy
Has thanked: 50 times
Been thanked: 84 times
Zero dollars and zero cents.
I just like working on 951’s and 968’s
Spencan wrote: Tue Jul 11, 2023 3:23 pm Just out of curiosity, how much do you charge for this service?
#21
gruhsy
Sorry I missed your question on this page.
You need 3 small orings
The rest you are correct on.
This is the 951 throttle body.
I have not taken apart a 944 or 968….yet :)
Spencan wrote: Tue Jul 11, 2023 11:31 am So correct me if I’m wrong here, I will need 1 large O-ring, 2 small O-rings, no flash contact cleaner, and 2 small circlips?
#22
kjell
Do you know if those O-rings are the same size on an N/A car? I've got a 1986 944 N/A with the most porous throttlebody seals I've ever seen and keen to try to buy some parts before taking it apart. I have been looking everywhere for an answer! Thanks!
#23
gruhsy
If you can measure the size of the throttle shaft and post a couple pics I can take measurements of the 951 kit when I get home
#24
I don't know if they are the same, but --at least where I live-- if I get my order into McMaster by 4pm, it shows up the next day, usually in the morning!
#25
kjell
Thanks!
I'm all the way over in England, but can still get O-rings pretty easily online if I know the sizes! I'll measure tomorrow and let you know!
#26
kjell
Pulled the TB and did some measuring, looks like this:
I think I may need a larger o-ring, how does yours measure up?
#27
gruhsy
Use a brass of soft pic to remove best practice.
951 throttle shaft is 8mm same size.
That means you will need a 2mm by 8mm O-ring.
The O-ring has to match the shaft size.
7mm is too small of diameter to fit on the shaft.
Confirmed by the bag of 7mm ones that I posted on an earlier post ….for a different use.
Width is 2mm
On the 951 you need two in the bearing on the TPS sensor side and one on the throttle cable side.
Hope that helps.
#28
mwc951
Has thanked: 14 times
Been thanked: 24 times
It went through 3 Arnnworx kits to rebuild 1 throttle body.
The damn butterfly screws were seized, kinked a couple o rings, PITA.
Doing the head gasket or clutch wasn't near as bad as rebuilding the TB!
#29
