Pressure Washers & Foam Cannon's
- Has thanked: 3445 times
- Been thanked: 975 times
Brian you can dry off your car with beer in hand, just add use the air jet handle on your small compressor --- sip along as you blow dry your sweetheart. Hmm ......why does that almost sound wrong?
BrianVA911
- Been thanked: 8 times
the guy with 69 total posts would say that.WillyDaP wrote: Wed Aug 16, 2023 10:56 am Brian you can dry off your car with beer in hand, just add use the air jet handle on your small compressor --- sip along as you blow dry your sweetheart. Hmm ......why does that almost sound wrong?
1983 911sc Targa
Rauch Quarz Metallic
Accidental for sure, but your powers of observation give me an idea you are a threat on a road course or autocross.
- Norville
- Has thanked: 20 times
- Been thanked: 57 times
$129 pressure washer, $600 in accessories
The hose reel makes life so much easier I wonder why I waited so long, wrestling with a loose hose to roll it up.
Ken
25 Carrera S
25 Cayenne Coupe S
19 Grand Cherokee
98 M3
25 Carrera S
25 Cayenne Coupe S
19 Grand Cherokee
98 M3
- Stormy_Monday
- Has thanked: 357 times
- Been thanked: 460 times
and your point?
Red Cars Rule
2022 718 Boxster GTS 4.0
2025 Cayenne e-Hybrid
2015 Ferrari California T
His point is simple, Norville is a " Clean Cut " Midwestern kid ! I need to show this picture to my wife and she will see I am not the only one who starts small and then expands till things are near perfection.
Norville, you win the " Best Home Powerwash " system on the Carpoke Forum --------until someone else goes for the esteem of Mr. Clean.
I am impressed, now how about some pictures of your spotless Porsche!
- Stormy_Monday
It is interesting how easy it is to fall into a rabbit hole on stuff.
Red Cars Rule
- Has thanked: 4605 times
- Been thanked: 2498 times
How true!!!!!!!Stormy_Monday wrote: Fri Aug 18, 2023 5:29 am It is interesting how easy it is to fall into a rabbit hole on stuff.
But it is fun! (And often beneficial in more ways than one.
- Has thanked: 277 times
- Been thanked: 274 times
I used to get a lot of local criticism about spending hours making things convenient just to save minutes later. That's calmed down a lot lately, or maybe I'm just growing deaf to it. That hose reel with the high-pressure swivel is interesting. The super-flexible hoses described in the videos are a lot nicer than the more rigid hoses I've got now. One can see how a foam cannon can easily make a normal slope quite slippery.
For car washing, volume (gallons per minute or Gpm) is key. More water allows you to evacuate the suds more completely and promotes the sheeting effect.
I use an Active pressure washer. 2.0 Gpm and the psi with my foam cannon tip is about 1450 psi if I recall. Love the setup.
I use the MTM pressure nozzle gun as well. Lots of suds with my Carpro Reset shampoo.
M
M
