Timing Belt Tension Poll....
What do you use to set the tension on your 944 timing belt?
Factory 9201 Tool
8
17%
Arnnworx tool
16
34%
Krikit tool
1
2%
By feel and/or 90 degree twist/water pump slippage
18
38%
Factory spring tensioner/Other
4
9%
Total votes: 47
danmartinic
Has thanked: 23 times
Been thanked: 41 times
You're missing an option for the poll: auto-set via the spring loaded tensioner (that's what I've been using since 2008 and over 120,000 miles of daily driving)
Seems to be work fine. I do take the tensioner off, clean and lubricate it before installing
Been thanked: 4016 times
danmartinic wrote: Thu Jun 16, 2022 7:45 am You're missing an option for the poll: auto-set via the spring loaded tensioner (that's what I've been using since 2008 and over 120,000 miles of daily driving)
Thanks. I'll add it. Did you click 'other'?
danmartinic
Yep that's me
Tom wrote: Thu Jun 16, 2022 8:10 am
gruhsy
Has thanked: 48 times
Been thanked: 81 times
How about machine pistons or order custom with valve relief and make non interference?
blade7
Has thanked: 25 times
Been thanked: 22 times
Water pump pulley twist method for the cambelt. Just replaced the belts and pulleys for the 2nd time in 20k miles/10 years.
Darwin
Has thanked: 116 times
Been thanked: 74 times
My auto tensioner always over tensions my belt. I have one of the early arnworx tensioning tools before he switched to the one that looks more like a 9201. Works great, with no complaints here.
2012 VW Tiguan - Kinda stock
So for the people who don't use the factory tool or the Arnnworx, what do you do for the balance shaft belt??
Latitude48
Has thanked: 103 times
Been thanked: 113 times
Darwin wrote: Sat Jun 18, 2022 1:10 pm My auto tensioner always over tensions my belt. I have one of the early arnworx tensioning tools before he switched to the one that looks more like a 9201. Works great, with no complaints here.
I've compared the spring tensioner on my S2 against the result using the P9201 tool and it's been "close enough." My new belts are due for a recheck soon and I'll make another comparison to see if it's still good.
Tom Pultz
Darwin
Latitude48 wrote: Sat Jun 18, 2022 5:03 pm
Nice. I'm not saying all tensioners are bad, but I feel like relying solely on something like that when literature doesn't say to do so is potentially asking for trouble. I'm sure with the manufacturing variance in springs, you can check to see where the tensioner puts it, but to say they all put it where it needs to be is a little too trusting IMO.
#19
danmartinic
Tom wrote: Sat Jun 18, 2022 3:28 pm So for the people who don't use the factory tool or the Arnnworx, what do you do for the balance shaft belt??
Super floppy until it barely hangs on to the sprockets :thumbup:
#20
