Brake Fluid??
johnb
Has thanked: 121 times
Been thanked: 93 times
Haha that's awesome. I remember my first time in Fry's on one of my first trips to the US before I moved here. I had heard of it but nothing could have prepared me for the sheer size of the place. The one that's near me now was in bad shape for the last few years though. I would go there and think, how is this place still going? Almost all the electronics shelves were empty or half empty. Funny thing is, just before they closed up, their website still sucked!
Zirconocene
Has thanked: 81 times
Been thanked: 53 times
The color in the brake fluid is nice to have so that you know when you've bled enough fluid through, supposing that you switch between the gold and blue every time.
To make the blue you can buy some dye separately and it only take a couple of drops to really tint it. The dye is specially formulated for these fluids, so there's no compatibility issue.
1990 928 GT
1990 928 S4
1991 944 S2
1993 968
2002 911 C2
johnb
Zirconocene wrote: Sun Jun 05, 2022 11:25 am The color in the brake fluid is nice to have so that you know when you've bled enough fluid through, supposing that you switch between the gold and blue every time.
I never really understood that idea. I mean, clearly it can't hold much more than a normal sized bottle (a quart or a litre, whatever they are). If you just put one of those through, it's all fresh. And there's no point in using less than that since once you open the bottle, it'll start to absorb moisture from the air.
Has thanked: 962 times
Been thanked: 4161 times
Well I just finished up and am happy to report no fuel leaks and solid brakes. What a fiasco overall, starting with the burst fuel line. How often to folks generally change the rubber brake fluid lines to the calipers? Mine looked 'ok' but couldn't help but think it might be wise to replace them...
Zirconocene
I did it as soon as I bought my car but I sort of assume that's the "standard" timeline: at the changing of owners' hands, or major systems refreshes. Of course, the lines on my car looked original and likely were. It's probably a good idea to do when/if you rebuild the calipers and just bundle everything together.
I love my Motive for what it helps me to do but I always fear what happened to you, @Tom .
Glad all is good
1990 928 GT
1990 928 S4
1991 944 S2
1993 968
2002 911 C2
Has thanked: 538 times
Been thanked: 279 times
Ahhhh, another item to add to my to-do list....flush the brakes!
BTW, the latest Pano's first article in the Tech Q&A is on a soft brake pedal on a 95 911. Long story short, the recommendation was a DOT4 low viscosity fluid, ATE SL6. Perhaps only needed for ABS equipped units.
whalenlg
Has thanked: 8 times
Been thanked: 119 times
Anyone know what dye to use?
1986 951 - Silicon Valley
stitch2k1
Been thanked: 30 times
Tom wrote: Sat Jun 04, 2022 10:32 am Is the ATE Type 200 the same thing, just in the regulatory Gold color? Is that the 'it' brake fluid these days for a street car, or has something else taken over in Porscheland?
Late reply, but yes. It's what I use in any street car. I think maybe if you were driving a dedicated racecar you could maybe find the boiling point. I also use it in the clutch, no surprise. When I bled my first 944 I found solid black clutch fluid in it.
It's quite cheap on Amazon too, like $21 a can right now for 1L.
Porsche 944S2 5MT '91
BMW E39 540iT 6MT '00
IG: @stitch2k1
#19
gruhsy
Has thanked: 50 times
Been thanked: 84 times
#20
