944 revival after sitting for 16 years
944er
Has thanked: 14 times
Been thanked: 64 times
I would not recommend PLA for any automotive application. Its resistance to temperature is insufficient. You may think it is cool enough under the car, but that is where the air passing through the radiator exits. I would recommend you reprint your clamps with CF or glass filled ABS (or ASA) at minimum.
Teapurist12
Has thanked: 4 times
Been thanked: 5 times
944er wrote: Thu Oct 10, 2024 3:54 pm I would not recommend PLA for any automotive application. Its resistance to temperature is insufficient. You may think it is cool enough under the car, but that is where the air passing through the radiator exits. I would recommend you reprint your clamps with CF or glass filled ABS (or ASA) at minimum.
this print with the PLA-cf was mostly just for testing purposes and to make sure the concept works- I will be printing with a PA-6 or PA-CF but not for these tester pieces due to the expense
1987 944 lux 2.5 8v
1977 land rover series 3 LWB 2.25 petrol
1954 MG TF midget 1250
2002 Volvo v70 2.4 manual
