We have a 2005 Boxster S. He has issues with the ABS, PSM, and the steering lock. Terminals 15 and 50 come up. PDF's would be great! The relay board does not have any labels on it either. One of them is clicking and causing a battery drain. When we swap the relay, it keeps clicking. That tells me that the fault is in the circuit controlling the relay, not the relay or the device. The steering lock is intermittent as well. There was water in the front well under the cowl area, and that may have caused some issues with corrosion.
Is there a diagram showing all of the grounding points? This car came from the coast of Florida, so we were going to clean the grounds. With terminal 15 and generally strange issues, I suspect something fundamental. It is going to be a challenge to sort it out. I have already lost most of my hair, but may pull the rest out before this is over.
Thanks.
Wiring Diagrams for troubleshooting
Here you goCruise98 wrote: Wed Jan 11, 2023 4:04 pm We have a 2005 Boxster S. He has issues with the ABS, PSM, and the steering lock. Terminals 15 and 50 come up. PDF's would be great! The relay board does not have any labels on it either. One of them is clicking and causing a battery drain. When we swap the relay, it keeps clicking. That tells me that the fault is in the circuit controlling the relay, not the relay or the device. The steering lock is intermittent as well. There was water in the front well under the cowl area, and that may have caused some issues with corrosion.
Thanks.
(40) CENTRE CONSOLE_20230111_164213.pdf- (31.72 KiB) Downloaded 119 times
(4B) PRE-WIRING, STEERING WHEEL ELECTRONICS (without MSW)_20230111_165512.pdf- (28.8 KiB) Downloaded 144 times
(4A) PRE-WIRING, STEERING WHEEL ELECTRONICS (with MSW)_20230111_163915.pdf- (31.86 KiB) Downloaded 127 times
( 4 ) INSTRUMENT CLUSTER STEERING WHEEL ELECTRONICS_20230111_163411.pdf- (54.19 KiB) Downloaded 91 times
(12) PSM (Porsche Stability Management)_20230111_163207.pdf- (59.34 KiB) Downloaded 123 times
Zirconocene
- Has thanked: 78 times
- Been thanked: 48 times
I don't know if this is still needed or active, it's been a little while, but I was able to find wiring diagrams for the 987.1 and .2; they're out there on the interwebs with a little bit of googling.
If you still need something, I can figure out how to send you what I've found.
Good luck
Good luck
1990 928 GT
1990 928 S4
1991 944 S2
1993 968
2002 911 C2
1990 928 GT
1990 928 S4
1991 944 S2
1993 968
2002 911 C2
