Hi All,
So I finally connected my battery charging my 992 GTS, I left the frunk semi-closed, not completely closed. And I noticed while charging, the door handles stay "out" while it is charging. Is that ok? Keys are not near the car. Is it because the frunk is still open?
Eric
Door handles out while charging on 992
- Hawk
- Has thanked: 131 times
- Been thanked: 116 times
If you run your maintainer wire out of the gap in the frunk by the windshield (close to the fender) you can close the frunk lid completely. Then you can lock the car. That will also put the car's various systems to sleep over time. That is the procedure I used with my 992 Carrera.elm310 wrote: Fri Jun 10, 2022 12:26 pm Hi All,
Eric
Dick
@Hawk I just afraid that the positive alligator clip will contact the frunk. That is the only reason that I left it semi-open. It is weird on how to clip the alligator connectors. Not much room on the positive side of the battery.Hawk wrote: Fri Jun 10, 2022 12:52 pmIf you run your maintainer wire out of the gap in the frunk by the windshield (close to the fender) you can close the frunk lid completely. Then you can lock the car. That will also put the car's various systems to sleep over time. That is the procedure I used with my 992 Carrera.elm310 wrote: Fri Jun 10, 2022 12:26 pm Hi All,
Eric
Eric
2022 911 Carrera 4 GTS
2009 BMW e92 M3
2014 BMW f10 535i
2017 Nissan Frontier SV
2019 Yamaha AR210 Jetboat
2009 BMW e92 M3
2014 BMW f10 535i
- Hawk
I did not experience that issue as I didn't use or try the alligator clips. I used a hard wire connection / extension off the battery and ground that I ran into the frunk and simply would plug into.elm310 wrote: Fri Jun 10, 2022 1:02 pm@Hawk I just afraid that the positive alligator clip will contact the frunk. That is the only reason that I left it semi-open. It is weird on how to clip the alligator connectors. Not much room on the positive side of the battery.Hawk wrote: Fri Jun 10, 2022 12:52 pmIf you run your maintainer wire out of the gap in the frunk by the windshield (close to the fender) you can close the frunk lid completely. Then you can lock the car. That will also put the car's various systems to sleep over time. That is the procedure I used with my 992 Carrera.elm310 wrote: Fri Jun 10, 2022 12:26 pm Hi All,
Eric
Eric
Dick
- Hawk
@elm310 What type of battery are they using in the GTS? Is it the LiFePO4 or AGM?
Dick
- Has thanked: 936 times
- Been thanked: 4025 times
I've charged mine without the door handles sticking out. I have the lithium battery and, from memory, the alligator clips things weren't close to the hood, so I did shut it that way (though now I'm wondering if I just overlooked that risk?). I'm guessing your door handles stayed up because the frunk wasn't fully latched...
@Hawk the dealership told me that I have the AGM battery, not the Li.Hawk wrote: Fri Jun 10, 2022 1:52 pm @elm310 What type of battery are they using in the GTS? Is it the LiFePO4 or AGM?
Eric
2009 BMW e92 M3
2014 BMW f10 535i
2009 BMW e92 M3
2014 BMW f10 535i
I'm going to look again, I might have space also and will shut the frunk completely. That should take care of the door handles.Tom wrote: Fri Jun 10, 2022 3:02 pm I've charged mine without the door handles sticking out. I have the lithium battery and, from memory, the alligator clips things weren't close to the hood, so I did shut it that way (though now I'm wondering if I just overlooked that risk?). I'm guessing your door handles stayed up because the frunk wasn't fully latched...
Eric
2009 BMW e92 M3
2014 BMW f10 535i
2009 BMW e92 M3
2014 BMW f10 535i
@Tom and @Hawk it's all good. Did have enough room between clips and frunk, so I went ahead and fully closed the frunk and in a few seconds the door handles retracted to closed or normal mode. Thank you both.
Eric
Eric
2009 BMW e92 M3
2014 BMW f10 535i
2009 BMW e92 M3
2014 BMW f10 535i
