Door release issue - Stumped!
Outlaw944
Has thanked: 19 times
Been thanked: 19 times
Hi All,
Seeking any door mechanism experts here. I have an issue with the drivers door release. I have changed the lever and I am on the last thread with the plastic ball joint connector, however the door still won't release from the outside. the handle will depress fully but doesnt seem enough to relase the catch.
Anyone had similar issues?
Thanks,
Anthony
gb951
Has thanked: 24 times
Been thanked: 37 times
The short answer is that your door handle is worn out. The working surfaces of the handle itself have worn through the black anodizing and have lost motion at the critical part where the trigger moves the rest of the linkage.
If you were to time travel back to the 80s, a bit of lubrication at that point might extend the life of that handle, but in the current day, the only real solution is to source a new handle that is not worn out and lubricate the contact points (lithium grease seems to work well.)
Outlaw944
gb951 wrote: Fri Feb 06, 2026 5:50 am The short answer is that your door handle is worn out. The working surfaces of the handle itself have worn through the black anodizing and have lost motion at the critical part where the trigger moves the rest of the linkage.
Thanks. I have a second hand one I managed to get for free that I planned to try out. Will see how that goes before/If i commit to a brand new one.
Thanks!
gb951
Here in the USA, it is almost always the driver side door handle that wears out. I often thought that sourcing the door handle from a country with right hand drive might work out, since they have the driver and passenger side swapped. Less usage > less wear.
Unfortunately, tariffs have made this option less appealing.
whalenlg
Has thanked: 8 times
Been thanked: 112 times
I had a similar problem a few years back and replaced the main ~6” vertical shaft with a new (and stiffer) one. No problems since.
It’s worth replacing the plastic parts at the same time.
1986 951 - Silicon Valley
Outlaw944
Update
Managed to get a second hand handle. Swapped out the barrell and other parts Along with a new lever catch. Fitted back on today and all works well.
07turbeaux
Has thanked: 13 times
Been thanked: 7 times
I have the very same issue though once in a handful of attempts it will open.
Cant the passenger side door handle work on the drivers side?
07turbeaux
where is a good source for parts as whalenlg found?
whalenlg
I got it from Gaudin Porsche in Las Vegas - just looked to see it’s $70 now.
Outlaw944
07turbeaux wrote: Sat May 02, 2026 8:17 pm I have the very same issue though once in a handful of attempts it will open.
I dont beelive they can be swapped although I never tried.
