Yes, that looks weird John. As if they're trying to fit a square peg in a round hole??Fast951 wrote: Sat Feb 14, 2026 9:29 am To the OP.
The paper gasket, in your posted picture, is damaged or someone modified it. Examine the shape of the drain hole.
Turbo Oil Seal Vitesse
- Has thanked: 961 times
- Been thanked: 4160 times
How thick are those? The original white ones seemed thicker. I have an original I'll measure if I can find it...
Annoying that they posted a picture of the thicker one and sent you that. Hopefully it still seals fine... Please report back either way, as I'm sure this will come up for others...
Another one that looks similar to original and measures 2” same center hole to center hole https://www.driftmotion.com/ProductDet ... 0&CartID=1
