Nice work, Tom. A good borescope is invaluable in this line of work, I use one several times a day on average.
I was about to remark that it is highly unusual for a peripheral head gasket coolant seal to suddenly begin pissing out coolant. Such a leak is usually a slow leak indicated by a buildup of crusty anti-freeze in the area of the leak. Anything sudden will be a combustion-related issue and will leak into a cylinder or two.
Coolant Leak at Oil Filter Housing Console
cda951
- Has thanked: 135 times
- Been thanked: 81 times
Chris A.
---'86 944 Turbo track rat
---'74 Jensen-Healey roadster
---other stuff
---other stuff
- Has thanked: 932 times
- Been thanked: 3991 times
I need to get a better scope. The one I have was $25 on amazon. Huge bang for your buck, but I'd love to have one where you can aim the camera once it's positioned. I've never actually seen an oil filter console spring leak like this either, but the nature of the gasket makes it seem more likely than the HG anyway. Either way, I saw it with my own eyes, so will be digging in shortly...cda951 wrote: Fri Dec 26, 2025 1:29 pm Nice work, Tom. A good borescope is invaluable in this line of work, I use one several times a day on average.
- Has thanked: 520 times
- Been thanked: 261 times
@Tom
Great video and appreciate your thought process for process of elimination and subsequent identification.
I also always like to 'see' whatever I'm diagnosing, even when tracking down a squeak or unwanted sound. Hearing a sound often gives general location, but looking at the area when the sound emanates was always the final action to identify the culprit. My logic is triangulation of ears and eyes.
Thank you for sharing.
This is why it takes me so long to fix anything... As I worked to get to the oil filter console, I was horrified to see rust on this little bracket that holds the brake sensor wire clip up where the sway bar bracket mounts. So ended up blasting and powder coating both sides. So satisfying
- Has thanked: 249 times
- Been thanked: 245 times
I think just about every little car task I take on ends up with a list of other little tasks on the way in and again on the way out. Sometimes the 'other little' tasks dwarf the effort for the original 'every little task'.
E.G.: As I put the car up on tall stands for storage a few weeks ago, I decided to go after a small gearbox drip that only shows up on the floor after a few months of winter resting. It isn't anything I thought it might be, at least so far. But in that same 'so far', the gearbox is lickin' clean, and since some of that 'clean' leaked out to the immediately adjacent tub, the rest will need the same...
I may need one of those special "rabbit hole" borescopes. The one that has the little shutters and a fisheye lens, so it maintains focus on only the symptom I happen to be searching for in that moment.
SoCal 928 Group Cofounder
- PSU_Crash
- Has thanked: 185 times
- Been thanked: 108 times
This is a prime example of why the "paint job" on my Starion took 5 yearsTom wrote: Mon Dec 29, 2025 7:24 am This is why it takes me so long to fix anything... As I worked to get to the oil filter console, I was horrified to see rust on this little bracket that holds the brake sensor wire clip up where the sway bar bracket mounts. So ended up blasting and powder coating both sides. So satisfying![]()
'86 Zermatt Silver 944 N/A
I need to fight the urge to make this a 5 year oil-seal job.PSU_Crash wrote: Tue Dec 30, 2025 5:07 pmThis is a prime example of why the "paint job" on my Starion took 5 yearsTom wrote: Mon Dec 29, 2025 7:24 am This is why it takes me so long to fix anything... As I worked to get to the oil filter console, I was horrified to see rust on this little bracket that holds the brake sensor wire clip up where the sway bar bracket mounts. So ended up blasting and powder coating both sides. So satisfying![]()
