Guess the tool
chris white
Been thanked: 175 times
Made many a custom 944 tools over the years. Had to use this one today, made it long time ago. Any guesses?
Has thanked: 962 times
Been thanked: 4161 times
A puller or press of some kind... but nothing obvious is coming to mind.
chris white
when doing a clutch job it can be bolted in place of the slave cylinder and the center bolt screws in to open up the pressure plate so that the torque tube will slip In to place effortlessly. Total cost…about 50 cents!
chris white wrote: Tue May 27, 2025 11:11 am when doing a clutch job it can be bolted in place of the slave cylinder and the center bolt screws in to open up the pressure plate so that the torque tube will slip In to place effortlessly. Total cost…about 50 cents!
Very nice!!
Belgian951
Has thanked: 75 times
Been thanked: 33 times
interesting!
michaelmount123
Has thanked: 33 times
Been thanked: 184 times
I like it! I presume you fit the TT shaft into the clutch, then screw in the bolt to allow the clutch disc to align with the pilot bearing. Yes?
I also used to use a couple of long 12mm bolts with the heads cut off (effectively studs) to get the TT in the right position for the shaft to go home. This, along with your trick tool may also be helpful.
Last edited by michaelmount123 on Sat May 31, 2025 2:30 pm, edited 1 time in total.
michaelmount123 wrote: Sat May 31, 2025 2:25 pm I also used to use a couple of long 12mm bolts with the heads cut off (effectively studs) to get the TT in the right position for the shaft to go home. This, along with your trick tool may also be helpful.
D'oh! Why didn't I think of that! Brilliant.
chris white
michaelmount123 wrote: Sat May 31, 2025 2:25 pm I like it! I presume you fit the TT shaft into the clutch, then screw in the bolt to allow the clutch disc to align with the pilot bearing. Yes?
yes, you will be amazed how easily the TT slips into the last inch or so!
