My Project - 72 911T
Has thanked: 4485 times
Been thanked: 2435 times
Tom wrote: Tue May 20, 2025 7:50 pm Looks like amazing work!! So clean. Can I ask what color that car is?
My guess is Signal Yellow.
The envelope please ...
AG81
Has thanked: 31 times
Been thanked: 60 times
Signal Yellow.
#42
Gaspowered
Has thanked: 297 times
Been thanked: 84 times
Love the color and the license tag.
Brian
'88 944 Turbo S / Silber Rosa
#43
Belgian951
Has thanked: 74 times
Been thanked: 33 times
What a gorgeous car. Such craftsmanship!
#44
AG81 wrote: Wed May 21, 2025 5:05 amSignal Yellow.
Simply an awesome color! Speed Yellow is fine too!
AG81
Ride height set and the alignment is finished.
#46
AG81
Engine 06.22.2025.jpg (821.93 KiB) Viewed 1690 times
Final Detailing on the engine. Built and balanced 2.7 with S and RS parts.
Magnesium Case (74) case split 4/9/24
Case vapor Blasted and Cerakoted.
Machine work on the case by Soren Anderson.
Pistons & Cylinders New Mahle flat top RS style. 90mm 9:1
Balanced Rods by Pauler Machine
Crankshaft work by Armando - Custom Crank Shaft
Head work by Pauler Machine
New main bearings, rod bearings and intermediate shaft bearings
Oil pump serviced for additional flow.
Supertec head studs
Supertec rocker arms
Port match heads and new PMO Intake
New modified S cams (Ed Mayo Spec)
CSF oil cooler
New PMO 40 Carbs
Turbo Valve Covers.
Wevo engine mounts
Engine assembled by Ed Mayo
Results are a very angry motor that loves 7,000 rpms
#47
Has thanked: 947 times
Been thanked: 4040 times
Looks fantastic. I bet that car scoots!
Armando was 'the' guy around here for years, then kind of disappeared. How does one reach him now?
#48
AG81
Tom,
I got to him thru a guy I met on Pelican. Doug who facilitated the process for me. I sent my crank out for magnafux and some other goodies only to hear "don't bother" with this crank. I then did some research and Doug came to the rescue.
#49
AG81 wrote: Mon Jun 23, 2025 11:21 am Tom,
But Armando ended up actually doing the work? I thought maybe he moved on. Glad to hear he's still doing cranks, but I have to say, Big Foot is easier to track down... :lol:
#50
