Vibration at idle
migreig
I just purchased my second 944 turbo (1986) a couple of weeks ago and I'm having an issue that I'm not sure where to start diagnosing. When I start it and it's cold, it vibrates aggressively and feels like it's idling really low, but sitting at 800-1000rpm which seems about right. It gets better as the engine warms up but never completely goes away. I have another one that idles smooth as glass so I know this isn't normal for this car. I am going to smoke test it for vacuum leaks this weekend but what else should I check?
In all other respects the car runs great. Pulls hard, lots of power etc. Where else should I be looking for an issue?
Thank you for any help!
1986 951 in White
1995 Volvo 940 Turbo
944m3
Has thanked: 22 times
Been thanked: 100 times
I would start with checking if your balance shafts are set/aligned correctly. Also check motor mounts. New OEM hydraulic mounts make a huge difference.
migreig
Good advice, I hadn't even thought of that. If the balance shaft(s) aren't timed correctly, would it be more noticeable at idle?
1986 951 in White
barnwerks
Been thanked: 36 times
Balance shaft (out of time) vibrations generally begin above 2500RPM.
I would unplug fuel injectors one at a time to identify if one has less impact at cold idle. Also test compression for correlation.
zooklm1
Has thanked: 19 times
Been thanked: 60 times
How are the cap, rotor, and plug wires?
944m3
barnwerks wrote: Sat Apr 26, 2025 3:53 am Balance shaft (out of time) vibrations generally begin above 2500RPM.
I would imagine that if balance shafts are out of time the vibration to RPM correlation would depend on how far off they are. Vibrations are usually smoothed out at higher RPMs meaning you will feel it at idle. I’ve personally experienced out of time balance shafts after doing a timing belt job.
Could very well not be the issue but easy enough to check and rule out.
migreig
zooklm1 wrote: Sat Apr 26, 2025 4:22 am How are the cap, rotor, and plug wires?
The car is brand new to me and I don't have any info on when they were changed last. That said, everything looks okay.
1986 951 in White
migreig
I did some reading late into the night and I've become convinced that the issue could be motor mounts. The symptoms I have seem to align with other people's complaints I found online about motor mounts. Apparently failed motor mounts causing heavy vibration at idle is not uncommon at all.
Shame if that's the case. Porsche motor mounts are exorbitantly expensive.
1986 951 in White
Wespa
Been thanked: 20 times
migreig wrote: Sat Apr 26, 2025 6:33 amPorsche motor mounts are exorbitantly expensive.
True, but luckily better alternatives exist. I've been using these for over a decade now, couldn't be happier with them: https://9productsamerica.com/shop/ols/p ... ine-mounts If everything else with the engine is sorted out these do not really introduce any extra NVH imho. At least if the balance shafts are still operating. :roll:
944 NA ROW -86
944m3
Definitely a common problem. Yes they are expensive. But there is science behind them, many articles online if you’re interested. The hydraulics or fluid filled motor mounts make a huge difference. I’ve used aftermarket mounts and they feel horrible and lasted maybe 2 years. Some will say it doesn’t matter and they don’t feel a difference. If I was 18 I probably wouldn’t care at all. But I value my comfort now :thumbup:
