Short Turbo Temp Sensor?
Spencan
Has thanked: 130 times
Been thanked: 31 times
Thanks Tom! I’m glad that it was an easy fix.
#21
markl951
Has thanked: 2 times
Been thanked: 10 times
Nice work @Tom. I figured it had to be something simple like that.
-mark
near Seattle, WA
85' NA 944 race car / 86' 944 Turbo
23' 718 Cayman GT4 RS
17' Macan GTS
#22
Bergerac
Has thanked: 20 times
Been thanked: 125 times
I ended up getting a bit creative with my temp switch due to how low my manifold sits, hopefully it can handle the heat , but im thinking it should be ok mounted in the water jacket part of the core. Obviously this is very turbo dependent.
#23
Has thanked: 943 times
Been thanked: 4032 times
Bergerac wrote: Fri Jan 17, 2025 6:06 pm I ended up getting a bit creative with my temp switch due to how low my manifold sits, hopefully it can handle the heat , but im thinking it should be ok mounted in the water jacket part of the core. Obviously this is very turbo dependent.
PXL_20241219_054408589.jpg.
I'm turned around a bit on that picture. What was that port for? Do you still have coolant flow through the turbo?
#24
Bergerac
Tom wrote: Fri Jan 17, 2025 6:41 pm
My turbo had 4 ports, the inlet from the pump is below the switch, the other outlet is plugged
#25
Bergerac wrote: Fri Jan 17, 2025 7:58 pm
Interesting, What turbo is that?
#26
Bergerac
The core is watercooled Holset HX35, the rest is a bit of a mishmash, the vendor was a bit contentious on rennlist/here , so I'm not going to go into too much more detail. May yet end up with a Garrett if it doesn't deliver
#27
Bergerac wrote: Fri Jan 17, 2025 8:07 pm The core is watercooled Holset HX35, the rest is a bit of a mishmash, the vendor was a bit contentious on rennlist/here , so I'm not going to go into too much more detail. May yet end up with a Garrett if it doesn't deliver
Got it, say no more....
#28
