Project status....
gruhsy
Has thanked: 48 times
Been thanked: 81 times
blade7 wrote: Fri Dec 20, 2024 2:08 pm Cosworth fitted an 8 injector inlet on the 87 homologation Ford Sierra RS500 Cosworth. The 500 road cars didn't come with the ECU to run all 8 injectors though. So the RS500 road cars only ran 4 of the 8 injectors, the same as the standard Sierra RS Cosworth.
You don’t mean RS200 do you?
With the 1.8L and 2.137L
#111
gruhsy
michaelmount123 wrote: Fri Dec 20, 2024 10:20 am Re the dual injectors: Porsche developed the engine back in the mid-1980's, some 40 years ago. At the time there were no large injectors available for motorsports. So what to do? Andial chose to run two 951 injectors off the Porsche shelf. It's currently set up to run both injectors simultaneously, and it does run sequentially as a 4 cylinder. The fuel rail is a custom piece to accommodate the dual injectors and the intake manifolds have been (beautifully) modified as well.
As an aside, the first generation 944GTR engine was developed by McLaren and used mechanical injection. The engine was deemed 'not ready' due to durability issues. Andial then took over engine development and converted to electronic engine control using a modified 962 Bosch ECU. They found the power and had success with the very early electronics. We're using MoTec due to the stability and capability of today's ECU's. Anyone notice the Kinsler DBW throttle actuator?
You learned me something new with Kinsler.
https://kinsler.com/Shop/
#112
blade7
Has thanked: 25 times
Been thanked: 22 times
gruhsy wrote: Sat Dec 21, 2024 2:03 pm
No, the RS200 is a completely different car.
#113
cda951
Has thanked: 136 times
@michaelmount123 Is the cam sync via the peg on the camshaft sprocket original to that engine, or did you add that as part of the Motec system?
Thanks again for sharing all of the pictures and information, what a machine!
Chris A.
---'86 944 Turbo track rat
---'74 Jensen-Healey roadster
---other stuff
#114
michaelmount123
Has thanked: 26 times
Been thanked: 179 times
The cam sync on the cam sprocket is an add-on, as is the crank sensor and wheel on the front of the crank. The modern sensors were deemed more reliable and front mounted to be more accessable and easy to service.
#115
michaelmount123
chris white wrote: Fri Dec 20, 2024 12:29 pm I looked over this car at the WGI Historic Races last summer (it was not running well). I couldn't figure out how it would run well with the MAP sensor on the plenum before the throttle bodies. I couldn't see any MAP sensor connections after the throttle bodies....kind of hard to tune (unless I was missing something)
Yes, Chris, tuning a turbo engine with ITB's is not common nor straight forward. The mapping is based on Alpha-N, (3D) but also references boost from the plenum resulting in 4D mapping. Smart people, these ECU geeks! We hope to be back on the dyno early in January. Still lots to do with the car.
#116
michaelmount123
GTR Engine.jpg (2.56 MiB) Viewed 2724 times
The engine is back in the car. Cleaned up a lot of things, and hope to be on the dyno this week.
#117
Has thanked: 936 times
Been thanked: 4016 times
Can't wait for the dyno -- looks like modern art!!
Is the skull and cross bones sticker a 944 cam belt joke? :lol: :lol:
#118
Thom
The First Carpoke!
Has thanked: 138 times
Been thanked: 153 times
Was the intake plenum also tested on the flow bench? It would be interesting to know how balanced it is.
'90 944 turbo
#119
walfreyydo
Has thanked: 28 times
Been thanked: 57 times
michaelmount123 wrote: Sun Jan 05, 2025 3:22 pm GTR Engine.jpg
So I was browsing facebook recently and came across the Porsche 944 GTR #3 page, and it appears to be the same engine. I believe only 7 of these cars were built. I assume this engine must be out of the #7 car?
Very very cool that you are working on one of these engines @michaelmount123! I think I read these make around 550hp?
Garage
#120
