944 / 968 battery cables
dcmachinist
JamesM wrote: Mon Nov 11, 2024 6:23 am Oops, I was on a different page, clicked on the female connector. I see what your saying now. still says active at the top of the page but it could be out of date
LOOK AT THIS!!! AMAZON: https://www.amazon.com/2-Pin-Connector- ... B0D6QXQCMK
#51
Has thanked: 932 times
Been thanked: 3994 times
dcmachinist wrote: Mon Nov 11, 2024 6:25 am
Wow, $40, I'm guessing the know what they have there. I'm tempted to throw the CAD file on the resin printer and see what I get...
Edit: bummer, I pulled up the model in Fusion, and the internals are not modelled at all.
#52
dcmachinist
Tom wrote: Mon Nov 11, 2024 8:49 am
I can take what they have and add the internals in Solidworks, Mastercam, or Fusion 360. I look at it later. I have a Photon Mono X sitting here in the closet.
#53
JamesM
Been thanked: 11 times
All it is is a hole with a rib for the pins to grab, with a connector it should be easy to model
I still am under the opinion that they are just out of stock and making a batch at my workplace we experience this pretty frequently as we use a lot of old Electronics parts. given TE still lists it as an active product I have relative faith they will be available again but who knows how long.
They do appear to sell a similar updated connector that could probably use the original pins and replace the factory connector
#54
four0four
Has thanked: 22 times
Been thanked: 32 times
LCSC appear to have stocked 926102-1 in the past, and will let you check out with any quantity (this will be converted to an RFQ and probably closed). You might be able to talk them into a low quantity quote (~100 should be $50) by directly inquiring though...Sometimes it's easier to get your hands on smaller quantities directly through distributors in China.
#55
Bergerac
Has thanked: 20 times
Been thanked: 121 times
JamesM wrote: Mon Nov 11, 2024 4:53 am Look at the porsche pet diagram, they have all the plugs and pins there. If not for some reason it looks like a standard molex plug so go on digikey or whatever your equivalent is and find it.
Its not any of the plugs in the PET
#56
Bergerac
dcmachinist wrote: Mon Nov 11, 2024 5:21 am
Bergerac wrote: Mon Nov 11, 2024 4:27 am
dstupakov wrote: Thu May 04, 2023 11:22 am Sure thing - here's the alternator harness I just got and where it plugs into on the firewall side.
Looks painfully similar to a standard 2 pin molex, but just a bit different.
Probably easier to just cut it off and go to a 2 pin DTM connector.
ll
Did anyone end up finding a source for this plug? dcmachinist wont ship overseas so I'm making my own harness
I will ship overseas - I just don't have it set up on my website because Weebly (Square) sucks. I have to copy and paste all customer info from from every order (even domestic) to USPS since Square bought Weebly. I used to be able to ship directly from my website. Jack Dorsey's greed ended that. They suddenly cut off that option unless I spend an extra $500+ over two years with them. I will be moving my website when my Weebly term expires to anyone not affiliated with Jack Dorsey, possibly self-hosting.
Anyone wanting to order overseas can send me a message through my contact form at the bottom of my site homepage.
You must of been having a bad day because you cancelled my order and accused me of being a scammer.
Its a moot point now Ive ordered cable and have the tooling to make my own. Thanks for sharing the connector information
#57
Bergerac
Ok Ive just managed to order 10 of the female connector s& 20pins which I what I needed to make a harness.
https://www.newark.com/amp-te-connectiv ... p/42AJ7614
https://www.newark.com/amp-te-connectiv ... dp/39K3781
They don't seem to stock the male half unfortunately.
#58
dcmachinist
Bergerac wrote: Mon Nov 11, 2024 2:46 pm
Bergerac wrote: Mon Nov 11, 2024 4:27 am ll
Bergerac wrote: Mon Nov 11, 2024 3:11 pm Ok Ive just managed to order 10 of the female connector s& 20pins which I what I needed to make a harness.
You can make 10 harnesses now! I wasn't having a bad day. I was having a bad year. Divorce, followed by having everything hacked to smithereens. I lost control of my root email account I'd had for 20 years and a bunch of other fun stuff. I couldn't log into my credit union, etc. over and over. I was running VPN with good security and all updates. It wouldn't have mattered. It's impossible to defend against an inside job. I apologize for cancelling your order, etc. It was an ugly time.
#59
