Something practical. And it dresses up the car a little bit.
The oil and water caps in the 718 Cayman are not labeled. There is no symbol to tell you which is which. Until you remove the caps, under which you find another set of caps that are clearly labeled.
I went to Minuteman Press and ordered these.
I've got a second set as backup. I want to see how these weather Texas heat. And I also have to skew my eyeballs to get the alignment better.
