944 DASH CLOCK TRIM COVER PANEL REPAIR
LoveBug951
Has thanked: 13 times
Been thanked: 9 times
STL PART FILE
944_Long_Trim_Clip_Fix.STL
This piece is for the Front Right Long Trim Piece on the 944 (Specifically my 951) that houses the clock, 12v outlet & Hazard light switch. This piece rests between the Heater Control Unit and the Dash.
After 30+ years this plastic gets brittle and can cause this tab to break off.
Before
NOTE
You might need to sand down the side of the trim piece as this is a tight press fit. You can permanently fix these pieces together with an epoxy if desired.
After
3D Print Settings
Printer: PRUSA i3 MK3 with Satin Powder-Coated Plate Sheet
Filament: MH Build PETG 1.75mm Black
Time: 33 minutes
Print Settings: No Raft, No Supports, 100% in-fill, .10mm UltraDetail
'89 951
Much Love <3
cp99
Has thanked: 4 times
Been thanked: 22 times
This is amazing. Do you have to plastic weld this piece to the factory trim?
Boston-area, MA
LoveBug951
cp99 wrote: Fri Aug 16, 2024 12:27 pm This is amazing. Do you have to plastic weld this piece to the factory trim?
Thank you!
No, you do not. It can just be press-fitted onto the side rail or can permanently fixed if you desire. I used thin double-sided tape inside the channel to adhere it to the factory trim piece then put a small bead of Super Glue Gel just for good measure.
'89 951
Much Love <3
Has thanked: 942 times
Been thanked: 4028 times
I missed this when you first posted it, but it's a brilliant design. Thank you for posting it! It could save quite a few pieces from the scrap heap!!
951N911
Has thanked: 5 times
Been thanked: 7 times
Wow, I need this exact thing. Thanks
1986 944 Turbo 3.0L
1974 911 Targa
2017 Macan GTS
Gone: 2006 997S, 2016 GT4, 1989 944 Turbo
LoveBug951
Tom wrote: Mon Aug 19, 2024 10:03 am I missed this when you first posted it, but it's a brilliant design. Thank you for posting it! It could save quite a few pieces from the scrap heap!!
Thank you! That's the hope.
'89 951
Much Love <3
LoveBug951
951N911 wrote: Mon Aug 19, 2024 11:44 am Wow, I need this exact thing. Thanks
I'm so glad this helps! Let me know how it turns out.
'89 951
Much Love <3
944S2Bob
Has thanked: 39 times
Been thanked: 4 times
Just what I needed. Thanks for doing this!
Bob
1991 944 S2
LoveBug951
944S2Bob wrote: Sat Dec 28, 2024 6:23 pm Just what I needed. Thanks for doing this!
I am so glad it helped!
'89 951
Much Love <3
