718 PSE Exhaust Valve Rattle (SOLUTION)
J-Dub
Has thanked: 660 times
Been thanked: 568 times
Update on my PSE rattle, some of the E-Clips fell out. They seem to not do well after being spread over the axle shaft of the valve. Possibly I should have sprung for the stainless versions of the E-Clips.
Today I tried Stainless safety wire, wrapped it around three times, twisted the two ends together so it won't come loose and tucked the tail out of the way. Hoping for a longer term solution.
1957 VW Beetle
2004 VW R32
2021 Porsche Cayman GTS 4.0
#21
71eh
Has thanked: 200 times
Been thanked: 565 times
J-Dub wrote: Fri Mar 29, 2024 3:19 pm Update on my PSE rattle, some of the E-Clips fell out. They seem to not do well after being spread over the axle shaft of the valve. Possibly I should have sprung for the stainless versions of the E-Clips.
Any luck with the wire?
My solution I would say reduced it by 80% or so, but after time I could def hear it a bit again. I might try the wire.
But, I noticed something when I was faffing around with it again. Look at the picture. That little gap also has some play when you open close the value with your hand. I might try some wire there, because the clips I have on are still on and there is no play in the main gap.
If that does not work then.......,
'24 Porsche 718 Cayman
'21 Mercedes AMG GTR
'76 Triumph TR6
'23 Porsche Macan GTS (sold)
'22 AMG CLS53 (sold)
'22 AMG CLA45 (sold)
'20 AMG c63s (sold)
#22
Has thanked: 945 times
Been thanked: 4035 times
I could envision a spring-metal clip that slips into both joints at once like a speed nut, and keeps gentle pressure on both... ?
#23
J-Dub
I was googling for spring clips that could be installed but did not quickly come up with anything. I am sure something exists that could work, the wire trick seems like a good solution so far.
1957 VW Beetle
2004 VW R32
#24
71eh
J-Dub wrote: Tue Apr 02, 2024 5:01 pm I was googling for spring clips that could be installed but did not quickly come up with anything. I am sure something exists that could work, the wire trick seems like a good solution so far.
Can you share a picture of what you did with the wire? :angel:
'76 Triumph TR6
'20 AMG c63s (sold)
#25
J-Dub
I did not take any pictures but was thinking while I was doing it that I should take pictures for this conversation. ugg.
Next time I am down there I will get a picture.
1957 VW Beetle
2004 VW R32
#26
