Page 1 of 2
Tire/Wheel Change Question - 991.2
Posted: Mon Aug 08, 2022 6:23 am
by Davesnums
Ok - this seems like a dumb question but I just went through removal of my front wheels to access and remove the liners and then front bumper to install the radiator grills on my 991.2. I am thinking there must be a trick related to re-installing the wheels. I did get them on but the front wheels don’t lock in place when in gear and brake is on - they just spin. This makes it a pain to re-install the wheels. (This is a manual). Anyone have a trick to make this less of a pain. I did get them back on and the install of the grills went fine - just wanting to know for the future when I need to swap my brake pads.
Re: Tire/Wheel Change Question - 991.2
Posted: Mon Aug 08, 2022 7:46 am
Davesnums wrote: Mon Aug 08, 2022 6:23 am Ok - this seems like a dumb question but I just went through removal of my front wheels to access and remove the liners and then front bumper to install the radiator grills on my 991.2. I am thinking there must be a trick related to re-installing the wheels. I did get them on but the front wheels don’t lock in place when in gear and brake is on - they just spin. This makes it a pain to re-install the wheels. (This is a manual). Anyone have a trick to make this less of a pain. I did get them back on and the install of the grills went fine - just wanting to know for the future when I need to swap my brake pads.
A torque wrench eliminates that issue. Purists will tell you not to use a torque wrench to tighten lug nuts, but it's an extremely common practice at shops. I prefer not to use an impact gun myself, primarily because they often put marks in the lug nuts, and make them look old and beat up. What I do in that situation is cinch down the lug nuts in a star pattern by spinning the tire backwards with the wrench on the lug nut. By spinning the tire backwards, you can cinch it tighter then trying to hold the wheel etc. Once all lug nuts are on that way, and the wheel is 100% settled on the hub, I lower the car and torque to spec using a torque wrench (star pattern). Always a good idea to drive a few miles and re-check to torque too, as the wheel will settle in place as you drive. Most shops don't have the luxury of re-checking in a day or two, but they make up for that by over-torquing in the first place with a big impact gun....
Posted: Mon Aug 08, 2022 8:33 am
by audi4t
I have this gizmo
Thread it into one of the lug bolt holes hang the wheel and insert other lug bolts then remove
Pelican Parts has them
I had this for my Audi’s same principle on Porsche
Posted: Tue Aug 16, 2022 4:02 pm
by F355bob
I put studs on my 991.2 and it so much easier to take wheels off and on
Posted: Fri Aug 26, 2022 1:00 pm
by t1gerb0y
Why do you need the front wheels to lock in place? To torque down the bolts? After I mount the wheel, I usually hold it in place with one hand and tighten the bolts with the other as much as I can. Then once I lower the car back down, I torque down the bolts without the wheels spinning.
Posted: Mon Nov 28, 2022 6:24 pm
by Pcarnut
audi4t wrote: Mon Aug 08, 2022 8:33 am I have this gizmo
I had this for my Audi’s same principle on Porsche4635C569-50E7-4E82-A000-72D3F034A863.jpeg
I have never used one of these studs before. Do you buy 4, one for all wheels or do you just move it around?
Posted: Mon Nov 28, 2022 6:42 pm
Pcarnut wrote: Mon Nov 28, 2022 6:24 pm
You just need one to hang the tire on and then move on to the next wheel once the first is mounted. I also keep one in the car, for what exact reason I don't know...
So simple a device, yet so very, very helpful.
Posted: Mon Nov 28, 2022 7:53 pm
by Pcarnut
blueline wrote: Mon Nov 28, 2022 6:42 pm
Thank you. Ordering one now.
Posted: Mon Nov 28, 2022 7:55 pm
by Pcarnut
Pcarnut wrote: Mon Nov 28, 2022 7:53 pm
Well, not so fast. I refuse to pay $16.50 for shipping of a $14.25 part! I’ll look around.
Posted: Mon Nov 28, 2022 8:04 pm
Pcarnut wrote: Mon Nov 28, 2022 7:55 pm
Amazon. Very high quality. A pair in the pack. Free shipping. It's what I have in addition to a third one that I got a few years ago.
https://www.amazon.com/s?k=cta+tools+wh ... nb_sb_noss
Site not accepting the link to what I bought. I'll find a way to get info in a separate post.
