1988 NA odometer help needed
Posted: Thu Aug 06, 2026 5:39 pm
by Sparta49
THe odometer quit working. The speedometer works fine and it has a new gear. I was working and then quit then worked for a few miles and then quit again. Anyone have any ideas on where to start?
Re: 1988 NA odometer help needed
Posted: Thu Aug 06, 2026 10:56 pm
by Wespa
I had a similar issue years ago. It turned out to be the odometer gear teeth slipping off sideways from the receiving gear. I added a couple of really thin metal shims to the shaft to help keep the gear in place, and it has been functioning well since that.
Posted: Fri Aug 07, 2026 3:02 am
by gb951
You are probably going to need to take it apart again and see if one of the wires from the printed circuit board to the motor is broken, or if one of the solder joints has cracked.
Posted: Fri Aug 07, 2026 11:09 am
by PSU_Crash
I also added a shim after installing a new gear. It would work for a while, then quit. I'd take it apart and see nothing wrong. Then it would work for 1-200 miles and quit again. The shim was the answer for me. over 1k miles and still working.
Posted: Fri Aug 07, 2026 11:31 am
by Sparta49
Is there a way to add power to it while the cluster is out of the car so I can see what is going on?
Posted: Sun Aug 09, 2026 8:42 am
by PSU_Crash
Sparta49 wrote: Fri Aug 07, 2026 11:31 am
Yes, but it isn't as easy as just apply power. You need a square wave to drive the motor.
@Tom has a thread where he shows running the speedo/ODO on the bench. That was going to be my next move if the spacers didn't work out.
So far so good.
