Wire harness loop clips
zooklm1
Has thanked: 23 times
Been thanked: 61 times
Has anyone (Tom?) given any thought to 3D printing the plastic loop clips that hold the wire harness in place along the engine compartment and other areas? Like the blue and red ones? Thanks
Been thanked: 4085 times
zooklm1
Yes,
Awesome and thank you. Seems like they always break and I don’t have any around.
Thanks,
Lee
zooklm1 wrote: Sat Jan 24, 2026 4:35 pm Yes,
Thanks,
Lee
I made that one specific size because none of the factory ones seemed to be a good fit for the Kroon harness. You can scale it in your slicer if you need it bigger or smaller -- or let me know and I can adjust the model if needed. Be sure to use a filament that can take whatever heat it might see...
zooklm1
I saw when you made it you used Nylon-CF. Currently we have ABS and PET-G. I know ABS would give the temperature resistance (going in engine compartment). Not sure about PET-G. Thank you for the tip on scaling.
Lee
zooklm1 wrote: Sat Jan 24, 2026 6:46 pm I saw when you made it you used Nylon-CF. Currently we have ABS and PET-G. I know ABS would give the temperature resistance (going in engine compartment). Not sure about PET-G. Thank you for the tip on scaling.
Lee
For where I used them, I was worried that even ABS (my go to filament) might melt/deform since it was so close to the turbo. If near the exhaust or mounted on the motor, I generally use something with higher temp limits....
