944 Turbo Battery Replacement
Posted: Sat Feb 05, 2022 8:27 pm
What BATT are you guys running in your Turbo models......need to get a new replacement and heard mixed reviews on the Optima red/yellow tops.
Thanks
Thanks
https://carpokes.com/
yep, all batteries are made by either Johnson Controls or Exide.Tom wrote: Sun Feb 06, 2022 3:08 pm Autozone Duralast Gold here, Group 91 (aka H6). Autozone seems to have good prices and selection. Most lead-acid batteries are all made by the same 2 or 3 companies, so I tend to use the warranty length as a proxy for what's inside. I think the AGM batteries are fussier about battery tenders, no? I remember shopping for them and then going with the Duralast for some reason...
My car came with a state-of-the-1986-art stereo, radar detector behind the front bumper cap, and a massive CD changer the size of a VW stuffed in the wheel arch well at the back of the car. It physically moved CDs around inside like an old Juke Box. All of it was installed by Circuit City with a horrific lack of care/skill. The OP spend thousands on all this stuff, and they made every connection with jiggly vampire clips, and would just drill or cut anything remotely inconvenient. The capper was the rear wheel well area where they put the CD changer. It simply did not fit, so they cut out a chunk of the fender well about the size of a deck of cards so the corner of the CD changer could stick out. However, being mindful of corrosion and road noise, they sealed the whole corner up with a massive wad of clear silicon -- like the kind you use to seal a shower door. When I finally had a body shop fix it all, they gave me the silicon wad as a souvenir. It was about the size of a softball. But at least they didn't put a rain hole directly above my DME. Nature did that several years later.gpr8er wrote: Sun Feb 06, 2022 3:44 pmyep, all batteries are made by either Johnson Controls or Exide.Tom wrote: Sun Feb 06, 2022 3:08 pm Autozone Duralast Gold here, Group 91 (aka H6). Autozone seems to have good prices and selection. Most lead-acid batteries are all made by the same 2 or 3 companies, so I tend to use the warranty length as a proxy for what's inside. I think the AGM batteries are fussier about battery tenders, no? I remember shopping for them and then going with the Duralast for some reason...
I've had a Optima red top for over 10 years but I've heard that the new ones are "not as good" BTW it's really little too tall for the battery compartment. I like the AGM because of the no leak advantage.
This all reminds me of when I first got my car, The PO had a hack stereo shop install this monster setup in the car and when he ran the main power supply off the battery the idiot drilled a 1/2" hole through the bottom of the battery compartment. This genius also ran self tapping screws through the rear deck to mount his amps right into the gas tank. LOL
gruhsy wrote: Mon Feb 07, 2022 5:49 am Battery size difference if anyone is interested
V4 battery idea from this car thread
https://grassrootsmotorsports.com/forum ... 90/page12/
Here is a screenshot of the 96R I foundAudiSport wrote: Mon Feb 07, 2022 5:55 amgruhsy wrote: Mon Feb 07, 2022 5:49 am Battery size difference if anyone is interested
The DieHard AGM is a 96R I'm using also fits the factory mounts no problem and is a bit shorter for more clearance FWIW.
