Page 1 of 2
Another project done
Posted: Sun Oct 31, 2021 4:11 pm
by chris white
3.0 engine, nikasil with Mahle custom pistons, nice rods and fancy internals. Garret gtx series 2 turbo, 4 into 1 headers, link ecu, a bunch of Tial stuff and lots of plumbing. Trying a new boost control set up, seems like more fun than a round knob!
Re: Another project done
Posted: Mon Nov 01, 2021 6:03 am
by gruhsy
Nice work as usual.
How easy were the Mahle pistons to aquire?
When I can afford it I have to buy 1 set of 3.0ish pistons and 2 or 3 sets of 2.5l pistons as I have to Nikasil 3 blocks of my own and friends 2.5
Posted: Mon Nov 01, 2021 7:45 am
by AudiSport
@chris white Tell me more about the cam sync adapter and the intake pipe.
Posted: Mon Nov 01, 2021 8:15 am
by chris white
gruhsy wrote: Mon Nov 01, 2021 6:03 am
Nice work as usual.
No problem with Mahle, I have found they are the best company to work with. They will make anything you want and the manufacturing tolerances are way better than all the others I have worked with. Highly recommend
Posted: Mon Nov 01, 2021 8:19 am
by chris white
AudiSport wrote: Mon Nov 01, 2021 7:45 am
Intake pipe came with the car, needs a little repair!
The cam sensor is an Audi unit with my own adapter plate and trigger wheel. Hall effect and looks pretty cool.
I wasn’t a huge fan of the Lindsey manifold (owner already had it) but after working with it the access to stuff around the turbo is really nice
Posted: Mon Nov 01, 2021 11:09 am
by AudiSport
chris white wrote: Mon Nov 01, 2021 8:19 am
Do you sell those adapters and do you have a crank trigger or using flywheel? I'll need to get this figured out soon.
Posted: Mon Nov 01, 2021 11:21 am
by chris white
Yes, I also have a front mount 60-2 crank trigger wheel, sensor bracket and sensor (hall effect) that I have been making for quite a while. works great, easy to get to.
shoot me an email (
[email protected]) or call to discuss 315-636-8716
Posted: Mon Nov 01, 2021 12:10 pm
by SirLapsalot
Wish I would have known about that cam synch kit when I was assembling my standalone system. That's a very clean, nice looking solution. I like that it uses an OEM sensor too.
Posted: Mon Nov 01, 2021 3:34 pm
by Darwin
The cam sensor orientation is interesting.
Posted: Mon Nov 01, 2021 3:37 pm
by chris white
Darwin wrote: Mon Nov 01, 2021 3:34 pm
it will go 180 degrees if you want it. I just felt like pointing the wires down this time!
