Big red calipers
Posted: Fri Dec 29, 2023 10:33 am
by blade7
Is anyone here using the Dansk big red calipers, adaptors and 996 tt 330mm drilled discs on a non MO30 944 turbo? I know Lindsey sell a kit, but it doesn't look like they include disc centering rings.
Re: Big red calipers
Posted: Fri Dec 29, 2023 5:58 pm
by stitch2k1
M030 medium blacks would do you better, adapters are insanely cheap. If you get the new bias valve you move your front brakes to the back.
Posted: Fri Dec 29, 2023 6:22 pm
by blade7
Not much advantage in using adaptors to fit the same size calipers that I already have. And I fancy the bigger 996 drilled discs anyway. And my existing rear calipers and discs aren't very old.
