Big red calipers
blade7
Has thanked: 26 times
Been thanked: 22 times
Is anyone here using the Dansk big red calipers, adaptors and 996 tt 330mm drilled discs on a non MO30 944 turbo? I know Lindsey sell a kit, but it doesn't look like they include disc centering rings.
stitch2k1
Been thanked: 30 times
M030 medium blacks would do you better, adapters are insanely cheap. If you get the new bias valve you move your front brakes to the back.
Porsche 944S2 5MT '91
BMW E39 540iT 6MT '00
IG: @stitch2k1
blade7
Not much advantage in using adaptors to fit the same size calipers that I already have. And I fancy the bigger 996 drilled discs anyway. And my existing rear calipers and discs aren't very old.
