944 Spark Plug Wire Clip
Posted: Mon Sep 11, 2023 6:13 pm
Here is an .STL for the 924/944/968 spark plug wire holder. This is part # 052905471A and also fits some VW/Audi models. The examples below are printed in black ABS, to hold up to the heat under the hood, on a Bambu Lab X1C printer using the 'ironing' feature to produce a smooth top and bottom surface. It is a dead ringer for the original -- it would pass for stock even on close inspection by a picky concourse judge.
The pictures show the 3D printed versions next to a factory original.
944 Spark Plug Wire Clip by Carpokes.stl
Re: 944 Spark Plug Wire Clip
Posted: Mon Sep 11, 2023 6:16 pm
by cp99
Amazing and awesome at the same time.
Posted: Thu Jan 11, 2024 4:26 pm
by geniusanthony
Thank you for posting this, just found this forum after redoing the vacuum lines on my 86 Turbo. Just so happened to break a clip as I was putting things back together.
Posted: Thu Jan 11, 2024 5:09 pm
geniusanthony wrote: Thu Jan 11, 2024 4:26 pm
Welcome to Carpokes - glad you found the site and thanks for joining up!
Posted: Sun Feb 18, 2024 1:41 pm
by dssamusaran
Great I've a broken one holding with zipties for a while!
I'll try and print that in black PC for heat resistance
Posted: Sun Feb 18, 2024 2:58 pm
dssamusaran wrote: Sun Feb 18, 2024 1:41 pm
Given where they are in the engine bay, I've been using one made of ABS with no problems.
Posted: Mon Mar 23, 2026 3:36 am
by zooklm1
@Tom Are these sized for standard wire size or a “little loose” to accommodate a little larger wire (like Clewett 8 mm)?
Thanks,
Lee
Posted: Mon Mar 23, 2026 7:54 am
zooklm1 wrote: Mon Mar 23, 2026 3:36 am
Thanks,
Lee
They are as close to identical to the originals as I could make them. I printed mine in ABS and have been using them with the Clewett wires since the original post above. A smidge tight on the wires I guess, but no biggie. I could find the original model and make an 8mm version if you'd prefer, or I bet if you just printed them at 102-106%, somewhere in there you'd get just the level of grip you'd like on the thicker wires...
Posted: Mon Mar 23, 2026 8:20 am
by zooklm1
I will give the scaling approach a try.
Thanks,
Lee
