944 Spark Plug Wire Clip
Been thanked: 4078 times
Here is an .STL for the 924/944/968 spark plug wire holder. This is part # 052905471A and also fits some VW/Audi models. The examples below are printed in black ABS, to hold up to the heat under the hood, on a Bambu Lab X1C printer using the 'ironing' feature to produce a smooth top and bottom surface. It is a dead ringer for the original -- it would pass for stock even on close inspection by a picky concourse judge. :) The pictures show the 3D printed versions next to a factory original.
944 Spark Plug Wire Clip by Carpokes.stl
cp99
Has thanked: 4 times
Been thanked: 22 times
Amazing and awesome at the same time.
Boston-area, MA
geniusanthony
Thank you for posting this, just found this forum after redoing the vacuum lines on my 86 Turbo. Just so happened to break a clip as I was putting things back together.
Has thanked: 4519 times
Been thanked: 2452 times
geniusanthony wrote: Thu Jan 11, 2024 4:26 pm Thank you for posting this, just found this forum after redoing the vacuum lines on my 86 Turbo. Just so happened to break a clip as I was putting things back together.
Welcome to Carpokes - glad you found the site and thanks for joining up!
dssamusaran
Great I've a broken one holding with zipties for a while!
I'll try and print that in black PC for heat resistance ;)
dssamusaran wrote: Sun Feb 18, 2024 1:41 pm Great I've a broken one holding with zipties for a while!
Given where they are in the engine bay, I've been using one made of ABS with no problems.
zooklm1
Has thanked: 21 times
Been thanked: 61 times
@Tom Are these sized for standard wire size or a “little loose” to accommodate a little larger wire (like Clewett 8 mm)?
Thanks,
Lee
zooklm1 wrote: Mon Mar 23, 2026 3:36 am @Tom Are these sized for standard wire size or a “little loose” to accommodate a little larger wire (like Clewett 8 mm)?
Thanks,
Lee
They are as close to identical to the originals as I could make them. I printed mine in ABS and have been using them with the Clewett wires since the original post above. A smidge tight on the wires I guess, but no biggie. I could find the original model and make an 8mm version if you'd prefer, or I bet if you just printed them at 102-106%, somewhere in there you'd get just the level of grip you'd like on the thicker wires...
zooklm1
I will give the scaling approach a try.
Thanks,
Lee
