Flywheel lock print
Posted: Mon Aug 07, 2023 11:22 am
by Roman
Hi all, i am bout to 3D print flywheel lock for 944, i need to do al timing belts and camshaft housing gasket Do you think that 3D printed lock will be good enough for it, and will it hold with PLA or better to use ABS? Thanks
Re: Flywheel lock print
Posted: Mon Aug 07, 2023 12:40 pm
As I've said, no plastic printable on a typical home FDM printer will be strong enough to undo the front pulley bolt. It will break. On the other hand, if you just want to prevent the motor from moving off TDC while installing a belt, etc., then any plastic should be good enough for that.
Posted: Mon Aug 07, 2023 1:28 pm
by Roman
Thanks, pulley bolt will stay on, its purely just for holding TDC for timing.
Posted: Mon Aug 07, 2023 1:57 pm
by usury
Roman wrote: Mon Aug 07, 2023 1:28 pm
I did my belts last fall. A person doesn't strictly
need the flywheel lock. It takes deliberate effort to move the crank, even with the spark plugs out. Plus, confirming the timing mark is aligned in the bell housing peep hole will be reassuring prior to belt installation.
Though if I had a 3D printer to make a flywheel lock, I might have locked it regardless.
