Looking for DME BIN files
Trouble
Hey Tom, How much is it for you to produce one of those 3D printed ribbon pieces for me??? I also have the Lindsey Racing Modification on my ECU, But installing one of those pieces and Powder coating my cover will take it over the top!!!!
#71
Been thanked: 4024 times
Trouble wrote: Mon Jun 16, 2025 4:46 pm Hey Tom, How much is it for you to produce one of those 3D printed ribbon pieces for me??? I also have the Lindsey Racing Modification on my ECU, But installing one of those pieces and Powder coating my cover will take it over the top!!!!
Just PM me your name and address and I'll get you one. :)
#72
Oscar944T
I’m so glad I found this thread!!!
I’ve been doing research for DIY tuning and it looks like an Ostrich and TunerPro is the way to go.
Question: does anyone have experience with a DIY MAF conversion?
The hardware changes are doable but what I’m really after is the BIN file with the 3D fueling map for WOT.
From what I’ve read and my basic knowledge of standalone ECU tuning the stock 2D map for WOT is the limiting factor in getting these cars “well tuned”
Ideally I’d like to go MAF and add the MAP sensor etc as per the kits available (Lindsey Racing etc) but do it myself…
Any input would be greatly appreciated!!!!
#73
nurtekin429
Has thanked: 6 times
I have attached bin files.
Not tested
porsche ROMS.7z
(9.5 KiB) Downloaded 136 times
#74
whalenlg
Has thanked: 8 times
Been thanked: 111 times
Tom wrote: Sat May 24, 2025 6:05 pm I plan to do a more complete guide at some point, but in the meantime wanted to share something I finally figured out about TunerPro and Josh's xdf files. @whalenlg and I have discussed this in the past, and I was always a bit perplexed why he got different TunerPro behavior than I did.
Josh did a great job setting up the xdf file so that is makes sense to human eyeballs. In the WOT map, for example, the entries are shown as AFR number -- 14.7, etc. -- so when you edit the maps you can put in numbers that make sense to you, rather than trying to calculate the actual value that gets burned in the map. The problem I was having is that I couldn't get values lower than 12 to stick. I'd save 11 or even 10, and it would come back as 12 or so. Inspecting the XDF file, I saw that Josh entered 12 as the minimum value. The weird thing was @whalenlg was using the same xdf with the same minimum, but was able to save lower numbers. Fast forward to this afternoon, and I finally found the toggle where you can turn the limits on and off (or change the limits). Here are screen shots showing how/where to turn off or change the limits in case helpful to any frustrated would-be tuner down the road.
Start by opening the map that has the limit you want to change or turn off. Then go here....
And it pulls up this box where you can make the change.
I saw a news story today describing a guy with a BMW335 was able to use ChatGPT to generate a custom tune and it resulted in 1 sec faster 0-60 times.
https://www.autoblog.com/news/tiktoker- ... r-than-new
So - I gave it a whirl putting in what I think are the correct values for my stock 951 and asking to adapt to the new Evergreen RaptorX turbo + the 89 DME bin I am running.
Here's what ChatGPT came out with (complete with updated Partial Throttle Fuel Map, etc.):
I built a conservative Evergreen Raptor part-throttle fuel map tailored to your setup (AFM, EV1 40@3→[email protected] bar, ML3.1, CA 91). You’ve got:
AFR targets (12×12) for smooth cruise → pre-boost enrichment
RAW ECU values (already converted with X = round(128*14.7/AFR))
Delta vs your current map (AFR difference) so you can see changes
Download any/all:
AFR targets: CSV • Excel
RAW ECU values: CSV • Excel
Delta vs current (AFR): CSV • Excel
How to use:
Paste the RAW grid into your “Part-Throttle Fueling Map” in TunerPro (12×12).
Keep your WOT/boost maps as we set earlier (target 11.5–11.8 AFR).
Flash, warm up, and verify trims at idle/steady cruise (±5–8%).
Do light-to-medium throttle pulls and log AFR: you should see ~14.7 at cruise, easing toward 13.5→13.2 as you approach boost (3.2–4.6k), which is safer on CA 91 with the Raptor’s midrange.
If you want me to nudge this table “leaner” for mileage (slightly higher AFR in the 16–24% load columns) or “richer” for extra knock margin in hot weather, say the word and I’ll regenerate new files.
Will dig in deeper over the next few days
@Tom - might be interesting to compare what ChatGPT says for your setup and how the resulting maps look compared to yours.
1986 951 - Silicon Valley
#75
whalenlg wrote: Sat Aug 16, 2025 11:47 pm
Download any/all:
How to use:
What a world we live in... I'll give it a try for sure. Wonder if it knows where idle speed resides?
#76
whalenlg
Anyone have a .xdf file for the KLR? My deeper discussion with ChatGPT is asking for one & I can't get Google to find it for me...
#77
whalenlg wrote: Sun Aug 17, 2025 12:51 pm Anyone have a .xdf file for the KLR? My deeper discussion with ChatGPT is asking for one & I can't get Google to find it for me...
I've never seen one....
#78
whalenlg
I saw an old RL post with a link from 2009 - it didn't come up, but when I went to the full url of the poster, I pulled it up.
Post:
https://rennlist.com/forums/944-turbo-a ... f-q-s.html
File attached - but no idea how valid it is
KLR_XDF.zip
(1.38 KiB) Downloaded 105 times
#79
johnb
Has thanked: 110 times
Been thanked: 78 times
Hey Tom, I haven't been around here much in a while but I have KLR bins for stock, stock S, and Autothority if they're any use? I spend a huge amount of time during covid reverse engineering the KLR for the hell of it of documenting how it works (https://jhnbyrn.github.io/951-KLR-PAGES/). I haven't done anything with that project in a few years but I still have some notes for the unfinished sections.
The Autothority bin I have is one I just downloaded from somewhere, you probably have it already. I did disassemble it and compare it to the stock one and if I remember correctly the only difference was that they maxed out the target boost maps for all values, which I doubt would make much difference on its own without hardware changes.
Oh and I have a Dinan one too apparently...I forget what was different about that one.
#80
