968 Turbo boost problems whilst mapping
Thom
The First Carpoke!
Has thanked: 140 times
Been thanked: 159 times
Good to hear you may have found the issue.
As for wastegate location it seems the answer is in your own question as it makes sense to me that the closer to the head, the hotter the exhaust gas. Isn't there enough room around the stock wastegate location to somewhat locate both? I can't quite tell from the pictures but you use a 944T clutch bellhousing rather than the 968's bulky unit?
'90 944 turbo
#61
Rickuk1
Has thanked: 16 times
The saga continues out two new waste gates on the car with new control tubes still can’t get much past spring pressure any ideas ?
#62
ealoken
Has thanked: 46 times
Been thanked: 52 times
Can you show pictures of your setup and how your map / log?
#63
Rickuk1
ealoken wrote: Thu May 29, 2025 11:04 am Can you show pictures of your setup and how your map / log?
If you look at pages 1-3 on the thread you can see pictures of set up I’ll try to get an updated down load from ecu but I live in Mallorca and the car is in the UK so will need a little time
#64
ealoken
Rickuk1 wrote: Thu May 29, 2025 11:33 pm
I think your exhaust housing is one of your problems, 1.05 bleeds alot.
How are your ignition map and boost map?
Closed or open loop?
#65
Rickuk1
Found out one of the silicone hoses as a massive crack in it so creating a hard pipe with straight connectors to rectify hopefully this is the last thing
#66
Rickuk1
So latest update the boost leak appears to be fixed we have done a couple of street pulls I’ll show wider below any thoughts from the limited data on the video before we get back on the dyno
Rickuk1
Sorry can’t download the video it will not let me
#68
walfreyydo
Has thanked: 34 times
Been thanked: 64 times
In that screenshot, which appears to be a snapshot in time during a pull, AFRs seem ok, looks around low 12's (lambda 0.83), boost approx 31psi (217 kpa), but I am not sure what you are asking for feedback on with those screenshots.
What might be concerning is that Im also seeing your target lambda at 1.01 which is about stoic (14.7 AFR), and your EGO correction appears to be trying to pull fuel (88% enrichment), which tells me your target lambda/afr table may not be configured right and that is why EGO is trying to pull fuel in order to hit that 1.01 lambda target. That would be way too lean for running boost and should be corrected since EGO correction will be trying to constantly lean your mixture. 14.7/stoic is ok at partial throttle/cruising (ie cruising at highways speeds) but obviously under load you want more fuel or bad things happen. You may want to look at your target lambda/AFR table and make sure the cells are all set to the correct target based on load/rpm - but maybe I am not reading your screenshot correctly.
I am more familiar with Megasquirt/MegaLogViewer so I am not familar with the VEMS logger interface and how to fully interpret what you shared in the screenshots.
Sharing your target AFR/lambda, VE and Ignition timing tables in a screenshot would be helpful and could try to review those, if desired.
Garage
#69
ealoken
You need to figure out the enrichment.
How does your VE tables / ignition look like?
Here is a screenshot of my log.
11.8 af / 0.83 lamda is a bit rich but safe.
How are your EGT?
#70
