Well duh, it never dawned on me you were referring to Bezos. I got my no-drip quick couplings there, as well as the jumper hoses. I didn't read your post closely enough but now I see the best way is directly connecting the hose to the cylinder, that's my next job. I got the posts plumb with shims but I'm still getting uneven lifitng, I have a replacement divider I may try. Gotta get busy and swap out my GPF's now.dr bob wrote: Sun Feb 27, 2022 4:25 pm Apology for the lagged response --
I just tug sideways on the hose so it doesn't sit right over the bolt. My goal was to eliminate fittings and places it might leak.
And my reference to "Jeff B" is Bezos and Amazon. Sorry if that wasn't more obvious.![]()
Garage Lifts
- Bill in Bama
- Has thanked: 16 times
- Been thanked: 155 times
'84 944, my first Porsche DBM
- Has thanked: 961 times
- Been thanked: 4160 times
My lift has started groaning when it goes up. Anyone know if there is a particular reason for that and/or adjustment?
- Bill in Bama
The usual reason is low fluid, I'm assuming your is topped up. Pump issues, maybe air in the system causing the low fluid symptoms.
Bill in Bama wrote: Wed Sep 14, 2022 12:49 pm The usual reason is low fluid, I'm assuming your is topped up. Pump issues, maybe air in the system causing the low fluid symptoms.
Well I topped it off and it didn't make a difference. After googling more, I learned my cable pulleys have Zerk fittings for bearing grease. So I greased those up, used lithium grease inside the posts, and oiled the cabled with 90 weight (per the manual). The groan is 90% gone, but still groans at the very top. I'm temped to try some of the Cat 1u-9891 Hydraulic Oil Additive, which I've read is supposed to help... Anyone try it?
ryancassidy
- Has thanked: 2 times
- Been thanked: 24 times
Sorry I've been out for a bit and meaning to reply. I have been using marine grease and those fittings (I think there are 6 or 8 on mine, and then wiping down the cables with oil every 6 months or so. I have a slight bit of a groan in one spot about 1/2 way up but nothing I'm too concerned about.
Glad u got it headed in the right direction. Since my first few weeks with the lift, it's been working great. I do think thay shooting some grease in those zeros is a good idea, I try to go through everything that needs it every six months myself (trailer zerks, gates etc)
Cheers,
Ryan Cassidy
Ryan Cassidy
- Bill in Bama
I've used the Cat additive in my MaxJax, helps some with chattering. Since I don't have cables I have no experience with their maintenance. Sounds as if you're almost there.
ryancassidy
Where is the groan coming from? Is it coming from the ram or the pump itself?
Cheers,
Ryan Cassidy
Ryan Cassidy
I wish I could tell. I "think" the noise is coming from the posts mostly, but also think the posts are amplifying some kind of harmonic coming from the pump/ram. I wrote to my BendPak installer guy and he encouraged me to use the Cat additive, so now I just need to find some. The Caterpillar online store is down, and I haven't found it anywhere else yet....ryancassidy wrote: Sat Sep 17, 2022 5:26 pm Where is the groan coming from? Is it coming from the ram or the pump itself?
In the meantime, my lift now goes all the way up without making a peep.
ryancassidy
I have a similar groan that seems to be resonating from uprights, I don't hear it from the ram/pump, but like you said it's tough to tell. I'd be interested to hear what the CAT additive does when you obtain it.
I guess I need to go and re-lube everything again. Thx for the reminder
Congrats on it being back to normal now!
Cheers,
Ryan Cassidy
Ryan Cassidy
