- 426635249_1457190028214232_4548442725142825451_n.jpg (235.63 KiB) Viewed 6365 times
944 Turbo picture thread
Black944 turbo
- Has thanked: 13 times
- Been thanked: 127 times
@Pumba1983 thank you, same to your beautiful 1986!!!
- NCGermerican
- Has thanked: 141 times
- Been thanked: 92 times
That is a HUGE improvement and I think it looks very good. Looks like it could have come from the factory like that. Well done!Jc951 wrote: Fri Apr 05, 2024 6:24 am Couldn’t stand how the PO drilled 7 holes in the nose panel and put plastic grommets in them. Finally had them cut out, resprayed and black metal mesh installed.
Before & After:
- Has thanked: 4433 times
- Been thanked: 2407 times
What a difference that made - I can see why you wanted the holes gone. Big improvement, for sure!Jc951 wrote: Fri Apr 05, 2024 6:24 am Couldn’t stand how the PO drilled 7 holes in the nose panel and put plastic grommets in them. Finally had them cut out, resprayed and black metal mesh installed.
Before & After:
I have no doubt that is the case. In regards to this particular change however, my thoughts were that this was more about correcting a prior cosmetically subjective faux pas that was in need of some kind of correction.blade7 wrote: Fri Apr 05, 2024 4:56 pm It's a matter of opinion as to whether or not the opening there is counter productive.
- Belgian951
- Has thanked: 74 times
- Been thanked: 33 times
Looks clean! I'm sure it helps with the high temps under the hood.
Tom_N
- Has thanked: 70 times
- Been thanked: 26 times
Beautiful that shop is!Tom wrote: Sat Aug 21, 2021 1:32 pm We had 4 944 Turbos in the house today -- three Guards Red and one Silver Rose. That's a record for us here at Carpokes headquarters.
2004 40 Jahre #1342
