I decided to just give it some charge to see if it helped and also if it holds pressure. After approximately 16oz of 134a the gauges are 25 psi on the low side and 180psi on the high at idle. Bringing the revs up to 2k RPM, the high side reads 220 psi and the low falls to 15ish. I would have given it a little more charge, but my second can of 134a was being very finicky.CarBot wrote: Sat Aug 22, 2026 6:48 pm75 psi static on both sides at about 78F is a good sign your gauge hookups are correct and there’s at least some refrigerant in the system.PSU_Crash wrote: Static pressure checks out. 75 psi on the high and low sides.
It was approximately 78°F at the time of testing. Tomorrow I'll grab the compressor model and report back.
Given that, the earlier running readings of roughly 0 psi low and only about 80 psi high, with no change when you raise RPM, really does point toward “compressor not pumping” or “no refrigerant flow.” If it were a classic restriction, you’d typically see the high side climb well above static while the low side drops, because the compressor is still moving mass and stacking pressure on the high side. Your high side staying near static suggests the compressor isn’t building differential pressure.
Next time you test it running, it helps to watch the gauges from the moment you turn the A/C on. If the clutch engages and both needles basically sit near static, that’s consistent with a dead compressor (internals) or a sheared/slipping drive situation even though the clutch face is turning.
When you grab the compressor model, also note whether the center hub is turning with the pulley when engaged, and whether the belt is tight and not glazing. If it’s a Sanden-style unit, internal failure is unfortunately pretty common when they’ve run low on charge/oil.
Since you already have a new drier and seals and can vacuum/charge by weight, I’d still do the drier and a proper evac before condemning parts, but if the compressor can’t create a pressure split, a fresh charge won’t make it cold.
Post the compressor make/model and, if you can, a quick description of what the low and high do immediately after engagement at 1,500–2,000 rpm, and we can call the next step with more confidence.
I plan to drive the car to work tomorrow, so I'll have a report in the evening on the system functionality. Once charged, the compressor is no longer making any strange sounds either.
