Brake Hoses-?
I am planning on doing a PCA HPDE at Barber Motorsport Park (Leeds AL) in late July with my 86 944 turbo and need to do a brake fluid flush. This has reminded me that I probably should replace the rubber brake lines as I had one start leaking a couple years ago (and only replaced that specific hose). I know a lot of people like stainless steel braided hoses over rubber, but the car did come from the factory with rubber brake hoses. Any recommendations/experiences?
Thanks
Brake Upgrades, Advice, Experiences
- Has thanked: 4479 times
- Been thanked: 2433 times
First of all, that's great that you'll be at Barber! (I'm assuming that's the PCA-AL 2-day event there.) It would be nice if I could enter the event and meet you Lee but I've already signed up for a PTC event on the 26th. Anyway, have fun!
Brake lines - my gut feeling is to go with OEM-style but I have zero knowledge regarding what would be best for your 944 Turbo in that regard, so I'll let the ones who know better weigh in with their opinions. I will say that changing the lines for new lines of whatever type you choose is 1000% recommended. Definitely true for the flush too. An ultra high-quality, high-temp racing brake fluid is a must. Motul RBF 660 would be one of several good choices, assuming your car is suitable for non-silicone synthetic.
- Has thanked: 943 times
- Been thanked: 4032 times
I bought stainless lines for mine, Troutman from Pelican, but when it came time to install them, I opted to use Porsche parts instead. Couldn't put my finger on it, but I had questions about the quality and ultimately they seemed like a solution in search of a problem. They're DOT approved and I'm sure fine, but figured one less thing to wonder about by using factory parts.
- J-Dub
- Has thanked: 658 times
- Been thanked: 568 times
I have installed several sets of braided stainless lines as well as replaced with stock style lines many times. I agree with Tom that the quality of the aftermarket stainless lines seems to vary quite a bit. In one car I liked the stainless lines and in the other I went back to stock style as I did not trust the stainless lines.
Any rubber line that is 20 or more years old I would replace. If your 86 likely still has three of the OEM hoses on there I would get whatever you feel comfortable with but just replace them and do a full flush/bleed with new fluid.
1957 VW Beetle
2004 VW R32
2021 Porsche Cayman GTS 4.0
2004 VW R32
Going to throw in Spiegler Brake Lines. IMHO they are the best. Met with the owner years ago and he is a Motörhead. Worth checking them out. USA Made.
Here's a new thread started by @motoken regarding brakes and related on his 1986 944 Turbo.
Brake Improvements
Brake Improvements
- zooklm1
- Has thanked: 19 times
- Been thanked: 60 times
The link to the 944 Turbo brake thread that blueline added remind me that I wanted to follow up on this thread. I did change my lines with OEM hoses and flushed with Motul 600. My existing pads were at 5 mm and the front rotors were 0.7 mm above the wear limit and rears 1.5 mm. I had a blast at The HPDE and want to go back for more sessions. While I was not overly fast nor really hard on the brakes, I will replace my pads and rotors both front and back. I think I will plan to do 2-3 HPDE events a year and might try some local autocross events. I have read a bunch of reviews about popular high performance street and track pads and would like input from Carpokes members. For rotors I am thinking sebro or Zimmermann.
Glad that you got the hoses changed Lee.
Also, good to hear that you had fun at Barber - it's a fantastic track!
Regarding rotors, there are some posts earlier in this thread along with a few links back to others' entries on other threads regarding some of your questions. J-Dub and WillyDaP are using the excellent GiroDisc 2-piece rotors. I'm a hardcore fan of AP Racing's 2-piece J-hook rotors, pricey but so very good. Whatever rotors you get, if for track use, avoid drilled rotors as they will lead to premature cracking.
- zooklm1
I saw the discussion on the 2 piece rotors and they sound great but I don’t think my skills currently exceed the capacity of the factory system and I would need to “invest” serious coin in a “Big Red” upgrade kit.
I see rotors with grooves and EBC sells a rotor with grooves and dimples. Do they really do much for braking performance?
I saw a lot of good discussion Ferodo DS3.12 but they seem to have an eye watering price. Anyone have a source at a lower price point? Does anyone have experience with Hawk BLACK OR DTC-30?
Thanks
Thanks
