Cyberpunky
- Has thanked: 34 times
- Been thanked: 10 times
Hi @Tom
I am getting car back next week(finally after 2 years) but didn't think there was any difference with RHD dashes. Is there anything you need me to check to confirm?
Bruce
Bruce
Bruce
- Been thanked: 4080 times
For right-hand cars, the thing I'm unsure about is the black-out piece with the printed circuit board. It would "probably" fit on the right side of your clusters, and you could then install the LED kit just like in a left-hand car, but then the black-out thing wouldn't black out that little opening at the edge of the cluster. If you guys are ok being guinea-pigs, I'm thinking I can print mirror images of the black out piece and LED trays and I "think" that would work for your cars.... That assumes the dash on your car is just a mirror image of the left hand dash, unless you know otherwise?
Cyberpunky
I always thought Porsche would have used same for both cars as gauges are definitely the same. I can't see why they would make them any different as it would add expense for no benefit. The light here travels the same way lolTom wrote: Thu Mar 07, 2024 8:32 pm For right-hand cars, the thing I'm unsure about is the black-out piece with the printed circuit board. It would "probably" fit on the right side of your clusters, and you could then install the LED kit just like in a left-hand car, but then the black-out thing wouldn't black out that little opening at the edge of the cluster. If you guys are ok being guinea-pigs, I'm thinking I can print mirror images of the black out piece and LED trays and I "think" that would work for your cars.... That assumes the dash on your car is just a mirror image of the left hand dash, unless you know otherwise?
Bruce
Chdesign_79
- Been thanked: 1 time
Excellent news! Let us know when you have more available!
- Sharkfin951-981
- Has thanked: 3 times
email sent
Cheers,
Kevin
1981 928 manual (Owned from 1994-1999)
1988 944 Turbo (Owned since 1997)
2007 Boxster S
2014 Boxster S
Kevin
2007 Boxster S
2014 Boxster S
Synapse120
- Has thanked: 2 times
- Been thanked: 8 times
Getting on the waitlist, email incoming shortly
breilly951
- Has thanked: 4 times
- Been thanked: 18 times
Tom, email sent. Thanks Bruce Reilly
