Oil Pan Gasket - While I'm in there...
whalenlg
Has thanked: 8 times
Been thanked: 119 times
Also - I used and AN wrench with the an vice adapter to assemble the hoses
1986 951 - Silicon Valley
#131
zooklm1
Has thanked: 26 times
Been thanked: 62 times
Did you have problems getting the fittings to seal (hence the use of the Seco seals) or as a preventative measure? On the wrenches and vise clamp, did they give better performance over regular tools or primarily keep from scratching up the anodize on the fittings? I have used steel AN style fittings on high pressure ( 1,000 - 3,000 psi) hydraulic systems and never had problems with leaking at the face seal.
Thank you.
#132
whalenlg
Yes - I had some me air bubbles when testing the connections in a water bucket, so Pegasus recommended the Seco seals
Yes - the AN wrench and vice adapter provided a better grip
#133
zooklm1
Great info. Thank you for sharing.
Lee
#134
