718 ABS License Plate Mounts
Post things for sale here!
incursion
Is it ok to screw my plate directly to just the two top mounts only? My dealer didn't drill the bottom two holes.
#101
Been thanked: 4020 times
incursion wrote: Mon Feb 07, 2022 10:29 am Is it ok to screw my plate directly to just the two top mounts only? My dealer didn't drill the bottom two holes.
Do you have the Carpokes mounts? If so, definitely use all four! They are designed to work on bumpers with or without holes, so if your bumper has two holes on top and no holes on the bottom, that doesn't matter at all for the Carpokes mounts. Just line up the holes in the bottom mounts over the tiny dimples in the bumper where the drill holes would have done. Just make sure the license plate holes line up before pressing them on hard.
p.s., as if the factory mounting solution isn't 'questionable' enough, I've seen too many dealers that just drill two holes for the plate and let it bounce against the paint. :cry:
#102
incursion
Yes, I have the Carpokes mounts. Thanks for the clarification. Also, are the washers supposed to go on the frontside of the license plate or the backside?
#103
incursion wrote: Mon Feb 07, 2022 10:49 am Yes, I have the Carpokes mounts. Thanks for the clarification. Also, are the washers supposed to to on the frontside of the license plate or the backside?
It goes, bumper, mount, plate, (plate frame optional), washer, screw. So front-side of license plate if I understand the question correctly....
#104
incursion
Tom wrote: Mon Feb 07, 2022 10:53 am
Yes, thanks!
#105
DripFluent
@Tom
I emailed about acquiring these for my Golf. Here are two photos of the back that you requested.
I assume they'll just be able to stick onto that area as its flat and doesn't have any grooves or similar.
#106
Interesting. How are you supposed to attach your plate?? Are there dimples or bosses or anything to show where the license plate mounting holes should go?
Based on those pictures, I tend to agree that either set of our mounts would work, so probably the 718 versions since they are cheaper....
#107
DripFluent
Tom wrote: Mon Feb 21, 2022 2:23 pm Interesting. How are you supposed to attach your plate?? Are there dimples or bosses or anything to show where the license plate mounting holes should go?
The dealer would measure and drill. I asked them specifically to not to.
I’ll go w/ the 718 ones.
#108
Efren
Has thanked: 9 times
Been thanked: 14 times
Do any of these fit a 987?
#109
Efren wrote: Sat Mar 19, 2022 7:38 pm Do any of these fit a 987?
Yes, see Post #65 in this thread. We had to be a little creative and mix the sets, but works like a charm. Happy to make you up a set if you'd like. :)
#110
