Storch MAF Install Issue
MoeMonney
Has thanked: 5 times
Been thanked: 45 times
PSU_Crash wrote: Wed Aug 26, 2026 5:40 pm
MoeMonney wrote: Wed Aug 26, 2026 4:32 pm I have the Storch on two cars. Both have slight hesitation when initiating throttle. I adjusted the idle control screw also for a steadier idle and that helped. It’s not bad at all though and the cars both drive very nice all around.
One car has a vitesse k26/6 chip and the other a custom tune. The tuner said that the Storch MAF seamed to lean everything out throughout the rev range so he had to make new file and change the fueling on multiple sections due to this.
That goes along with everything else I'm reading. There is a lot of feedback about raising idle. It's even in the manual. I didn't have time to play with the FQS tonight. I did get 2 videos to show what I'm talking about.
First off, just a cold start. Not bad
https://youtu.be/wJHd6UFRfcU?si=tvtlE4JsJ3kqJbS6
I let it warm up a bit then took this to show the throttle position and reaction.
https://youtu.be/6yjn33iHVHA?si=pzFme-RoU6MZAFMG
Seams normal to me. When going from idle to WOT it has a slight delay.
chrischrischris
Has thanked: 7 times
I exchanged some emails with Storch a couple of months ago and Julius said that the newest kits have updated software intended to address some known issues (see direct quote below). I have no idea how to go about obtaining the new software or how to install it on existing hardware, but that might be something worth exploring.
"In fact, we recently updated the software for several of our MAF kits, including the one for the Porsche 944 Turbo. These improvements have resolved the lean-running condition that could occur under high load and high boost, as well as any hesitation associated with it.
PSU_Crash
Has thanked: 234 times
Been thanked: 127 times
MoeMonney wrote: Thu Aug 27, 2026 5:08 am
It is much more than a slight delay. The stock AFM did not have this issue. Most of that video is not going WOT. Any remotely quick changes in tip-in and it stumbles.
PSU_Crash
chrischrischris wrote: Thu Aug 27, 2026 6:27 am I exchanged some emails with Storch a couple of months ago and Julius said that the newest kits have updated software intended to address some known issues (see direct quote below). I have no idea how to go about obtaining the new software or how to install it on existing hardware, but that might be something worth exploring.
Definitely good information. I may reach out to them and see if it can be updated.
Thanks!
PSU_Crash wrote: Thu Aug 27, 2026 8:53 am
A a quick test, unclip the DME temp sensor (blue 2-pin JPT connector). That will richen the mixture quite a bit (maybe too much), but if it smooths out the stumble then trying the FQS is worth the effort to get to...
PSU_Crash
Tom wrote: Thu Aug 27, 2026 8:59 am
I'll give that a try and report back soon. It just so happens that I have this fancy tool for the FQS that I need to try someday anyways :D
PSU_Crash
I pulled off the sensor and .. it started. Also barely ran, wouldnt rev well and sounded like it had a 300 duration cam. So, I'd say that's too much fuel? 😄
PSU_Crash wrote: Thu Aug 27, 2026 6:22 pm
Yeah, sounds like overkill sorry. Hey, we tried. Give the FQS a try with the fancy tool.
What motivated the MAF -- trying to fix an issue? The factory DME/AFM combo create a near-perfect mixture across the board, under all environmental conditions -- the result of Bosch's army of engineers. Pretty tough for a small aftermarket company to match a factory calibration like that. Grump old man mode, but what's the upside?
PSU_Crash
Tom wrote: Thu Aug 27, 2026 6:41 pm
I was on board with giving it a shot. Now we know.
My stock AFM worked great and it has been running very well. The reason for the MAS was just one less wear point and potentially a little better throttle response. I also have a noticeable dip in torque around 3800-4k RPM then it's fine to red line. Maybe a MAS would smooth out that area? Plus newer electronics with (questionable) better fuel mapping and response time? That's what I was thinking anyways.
Reading around a bit, the torque dip I speak of shows up in a lot of dyno charts, so maybe that's nothing at all 🤷‍♂️
I'll play with the FQS tomorrow and report back. I really want this to work
#19
944m3
Has thanked: 28 times
Been thanked: 111 times
Full disclosure, I have an A-tune available for sale.
With that said, I do wonder if the Rogue A-Tune was a much better solution than a MAF trying to trick the DME that it’s an AFM signal. A-tune uses MAP and new code on the chip. Still keeps the AFM. My butt dyno did feel better throttle response and better torque everywhere. No hesitations.
I think the A-tune was a very underrated chip and MAP combo. Not sure why it wasn’t more popular. Maybe folks got scared off by having to splice the MAP sensor into the stock harness. It honestly wasn’t that hard.
#20
