Windows work with ignition off
Thom
The First Carpoke!
Has thanked: 140 times
Been thanked: 159 times
Here is what a German 944 S2/turbo manual and French 968 manual say about it.
In both cases, the window will operate with the door open and no key in the ignition barrel.
'90 944 turbo
O875
Has thanked: 47 times
Been thanked: 11 times
ROW handbook 944S2
Richey
Been thanked: 9 times
Well mystery solved.... Is there anything special about the power window relay or is it just a standard relay?
Screenshot 2026-06-24 at 11.51.32 AM.png (4.16 MiB) Viewed 140 times
soxnail
Been thanked: 7 times
Richey ,
When a relay has the transistor symbol in it, it means that there is some control logic built into it. So no its not just a general purpose relay.
window control relay.jpg (24.2 KiB) Viewed 135 times
Well I learn something new everyday.
This was the original rationale for the US rule. Apparently small kids were leaning on switches in cars and getting hurt or even dying. The rule apparently helped, but not enough. It's been a very active and on-going area of regulation, particularly with the advent of one-touch roll up windows, obstruction detection with auto-reversal, etc. Switches now need to be designed to prevent accidental activation (e.g., recessed or pull-up style buttons) unless other safeguards are in place -- which explains why a lot of modern window switches are the way they are. And... although this was a mostly a US thing when the 944 was being made, it seems the Europe has since jumped in with it own similar regulations. All this just for window switches... Hard to comprehend the overall labyrinth of international rules and regulations that car makers have to follow to produce a car these days. No wonder cars cost so much.
cda951
Has thanked: 148 times
Been thanked: 83 times
The power window relay remaining activated until the door contact switch closes was a feature on all the P-cars of the era, and is a common cause of battery drains----usually due to corroded door switches and/or body ground contacts. I've also seen a few bad window relays staying latched on with no external influence.
This was one of my first tests as an apprentice over 21 years ago, a customer 964 had a 250 mA drain, and my boss knew what it was right away. He handed me the factory electrical system manual with the wiring diagrams and told me to figure it out. It took me much of the day to figure out exactly why the power window relay was remaining activated, but I eventually figured it out, corroded door switch :) .
Chris A.
---'86 944 Turbo track rat
---'74 Jensen-Healey roadster
---other stuff
