Garrett GT 3071-63 turbo.
adonay
Has thanked: 2 times
Been thanked: 4 times
Tom wrote: Wed May 27, 2026 7:41 am The 951 crowd has always leaned into vendors selling turbos as Stage this, Voodoo that, Raptor, SuperX, etc. Somebody posts good results with one, and others jump onboard. It makes getting feedback on off-the-shelf turbos like this harder than you'd think it should be... That's not to say there aren't plenty of pioneers out there, but we could use more. :)
This :thumbup: But then again our crossover pipe is mostly to blame as most people are scared of welding or fabrication .
That Saied there has been people tunning the GT\GTX series on the 944 but no one i think has reported the 3071 most stuff is either 3076 or bigger . In discussions before everyone states it is to small for a 2.5l . Would love to see your findings .
chris white
Been thanked: 175 times
GTX series is pretty good but getting a little dated. Xonarotor makes some very nice turbos but some fabrication is needed to bolt them on.
What ever you pick go with the Tial hot side casting - much nicer unit.
blade7
Has thanked: 30 times
Been thanked: 22 times
chris white wrote: Sun May 31, 2026 7:21 am GTX series is pretty good but getting a little dated. Xonarotor makes some very nice turbos but some fabrication is needed to bolt them on.
What changed between the GT and GTX turbos?
PSU_Crash
Has thanked: 204 times
Been thanked: 117 times
blade7 wrote: Sun May 31, 2026 2:39 pm
According to Google.
"Garrett’s GTX line is a modernized evolution of their legendary GT turbochargers. The GTX features forged billet compressor wheels and advanced aerodynamics, offering a 10-20% increase in flow and higher boost pressure ratios without adding turbo lag."
blade7
Seems a bit odd that there doesn't seem to be any 944 owner impressions on the earlier GT version.
facboy
What xona would work with 2.5L 8v?
chris white
facboy wrote: Mon Jun 01, 2026 3:43 am
I have mine custom made to my specs.
ealoken
Has thanked: 46 times
Been thanked: 52 times
i had this on my 951, was a blast 3800-7000 rpm.
Also with a catcam camshaft, it would breath and pull to 7000.
blade7
It seems there's no magic turbo that brings boost on from around 2.5k revs and keeps pulling to 6.5k? Perhaps only a 3.0 engine can do that.
#19
ealoken
A 4 sylinder 2 valve non vvti head will never make good boost that low.
even if it makes boost, the engine design dont make any power under 3500-3800 rpm.
E85 will help you out.
#20
