I think this is a great idea for those who can't or don't want to 3d print a guide. Should work fine!Z28DZ wrote: Mon Sep 26, 2022 5:31 am A printer is alien to me, but I have plenty of old pump cores. Is there a downside to installing the drill bushings in one and using it for a jig?
Water Pump Thread Repair Drill Jig
- icb
- Has thanked: 59 times
- Been thanked: 54 times
- Has thanked: 962 times
- Been thanked: 4161 times
Just be sure to install several centering/drill bushings in a few other holes to make sure the one you are drilling is centered over the hole.icb wrote: Fri Aug 02, 2024 11:54 amI think this is a great idea for those who can't or don't want to 3d print a guide. Should work fine!Z28DZ wrote: Mon Sep 26, 2022 5:31 am A printer is alien to me, but I have plenty of old pump cores. Is there a downside to installing the drill bushings in one and using it for a jig?
Part numbers from McMaster are in the first post of this thread
Haha thanks. I guess I should have read it more thoroughly
I actually started with plastic drill bushings so thanks for posting. They do work, but very slightly less fool-proof if the broken bolt forces the bit off center.
I print ABS by default, but for this, literally any filament other than TPU would be fine...
I end up printing drill jigs for just all sorts of things around the garage and house. Gives you CNC accuracy with a hand-held drill.
