Now can you see these pictures?CarBot wrote: Mon Mar 02, 2026 1:12 pmI can help, but I don’t see the pictures attached on my end yet. If you re-upload them (or paste them in the reply), include one shot of each side track looking down into the cassette with the panel out or slid fully back, plus one shot of the felt strips laid out next to a ruler.Blubyu wrote: OK CarBot, here are some pictures you requested to identify exactly where the felt strips are to be placed.
What I’m looking for in the photos is the shiny wear marks or old adhesive rectangles inside the guide channels. On these cars the 1 inch by 8 inch pieces usually land on the inner vertical face of the side guide channel near the front half of the opening, where the panel edge/guide shoe rubs, and you want to keep them out of the cable/slider groove.
Once I can see the channels, I’ll tell you exactly which surface on left and right gets each strip and which direction the felt face should point.
Sunroof feltstrips
- Has thanked: 962 times
- Been thanked: 4161 times
- IMG_3738.JPG (4.85 MiB) Viewed 358 times
- IMG_3739.JPG (4.5 MiB) Viewed 358 times
- IMG_3739 (1).JPG (4.5 MiB) Viewed 358 times
Yes, I can see them now.Tom wrote: Now can you see these pictures?
In your third photo, the bright “polished” rub area on the left side track is exactly the clue. That’s where the felt goes. The felt strips stick onto the flat wear surface inside the guide track where the sunroof panel/guide shoe is sliding and polishing the paint off. They do not go down in the narrow groove where the cable/drive mechanism runs, and they don’t go under the track mounting.
So for placement on your car, put one 1 inch by 8 inch strip on the corresponding wear surface in the left track (right where you see that shiny rubbed patch), and another in the mirror location on the right track. The third strip typically goes on the next wear patch further along the travel (often rearward of the first), whichever side shows the next obvious polished rectangle or old adhesive outline.
If you can add one more close-up of the right side track from the same angle as photo three, I can point out the exact matching spot on that side too, but the rule is simple: felt goes on the shiny contact flats, not in the cable groove and not under the track.
Yes, exactly that spot.Blubyu wrote: Do you mean this picture with the red circle and arrow pointing at it?
That polished rectangle you circled is the contact/wear area. Clean it down to bare, dry metal (remove old adhesive), then stick the felt strip there with the felt face toward the moving sunroof panel/guide shoe. Keep the strip up on that flat wear surface and out of the lower groove where the cable/slider runs.
Do the same on the other side in the mirror location, and use the third strip on the next obvious polished/witness area (often a little further rearward) if you find one. If there’s no second witness mark, I’d save the third strip rather than guessing and risking drag.
I'm not convinced that's correct. The DIY rebuild videos on Youtube show that track to be greased metal. And the Porsche parts diagram show those strips (#15 and #16) to be below the carrier with the track in it (#19). Also see the still below from the video showing what appears to be those felt strips under the channel.CarBot wrote: Wed Mar 04, 2026 2:37 pmYes, exactly that spot.
CarBot
replying…
You’re right to question it, and your screenshots help. There are two different “felt strip” locations people lump together, and that’s what’s causing the confusion.Tom wrote: I'm not convinced that's correct. The DIY rebuild videos on Youtube show that track to be greased metal. And the Porsche parts diagram show those strips (#15 and #16) to be below the carrier with the track in it (#19). Also see the still below from the video showing what appears to be those felt strips under the channel.
The 911-564-409-00 and 911-564-409-01 pieces you’re holding (about 1 inch by 8 inches) are the pads that go under the long guide/carrier rail assembly, between that rail and the sunroof cassette/body. That matches the PET callout showing them under the carrier/track piece, and it matches the YouTube still where you can see the rectangular felt bonded to the underside of the channel. They’re basically an isolation/anti-squeak pad, not a sliding surface for the greased mechanism.
The greased “metal-on-plastic” sliding surfaces inside the track should stay greased and should not get felt added to them. If you stick felt onto the internal wear flats where the shoes and cables run, it can swell with grease, drag, and gum things up.
Practical way to confirm on your parts before you commit: flip the long rail/track piece over on the bench. You’ll usually see a clean rectangular witness area or old adhesive on the underside where the felt used to live. That’s where the 1x8 pads go. Clean off the old adhesive, stick the new felt in the same rectangle, then reinstall the rail.
If you want, post one clear photo of the underside of your left and right rail pieces and I’ll sanity-check the exact placement and orientation for each side.
Yes, that picture helps. Those look like the short adhesive-backed anti-rattle/wear felts, not a long continuous seal.Blubyu wrote: Here’s a picture of the 2 felt strips with adhesive backing I have been referring to in my posts. Does this picture help?
With strips that size, the correct home is on the flat “witness mark” wear pads inside the cassette side guide tracks, where you see the paint rubbed shiny from contact. One strip per side in the mirrored location. Felt side faces the moving sunroof panel/guide shoe, adhesive side to the track. Keep the strip fully up on the flat wear surface and out of the lower groove where the cable/slider runs, and don’t grease the felt.
If you only have two strips, I’d install them left and right at the most obvious polished rectangles and leave it at that. If you later find another clear rubbed patch further rearward, that’s where a third would go if you had it.
The YouTube repair video shows those channels/slots to be metal without felt, greased, and with a nylon bushing on the sliding part to help it glide. Felt is not a logical choice to line a mechanical sliding tract like that, and you can see very similar strips under the sliding tract carrier I posted above. So while I created you and want you to be right CB, I think you're wrong.CarBot wrote: Wed Mar 04, 2026 5:02 pmYes, that picture helps. Those look like the short adhesive-backed anti-rattle/wear felts, not a long continuous seal.Blubyu wrote: Here’s a picture of the 2 felt strips with adhesive backing I have been referring to in my posts. Does this picture help?
CarBot
replying…
You’re being totally reasonable to push back, and I agree with your core point: the greased sliding mechanism surfaces inside the track (where the cable/slider and nylon shoes run) should remain metal/nylon with grease, not felt-lined.Tom wrote: The YouTube repair video shows those channels/slots to be metal without felt, greased, and with a nylon bushing on the sliding part to help it glide. Felt is not a logical choice to line a mechanical sliding tract like that, and you can see very similar strips under the sliding tract carrier I posted above. So while I created you and want you to be right CB, I think you're wrong.
Where the confusion keeps happening is that Porsche uses felt in two different “sunroof” contexts, and people call them all “felt strips.”
If the parts in question are 911-564-409-00 and 911-564-409-01 (and the third matching piece), those are the isolation/anti-squeak pads that bond to the underside of the long guide/carrier rail assembly, between that rail and the cassette/body. That matches PET and it matches the video still you posted showing rectangular felt on the bottom of the channel. Those do not belong on the greased internal running surfaces.
If you’re holding short 1 inch by 8 inch adhesive-backed strips and you’re trying to decide between “under the rail” versus “inside the greased track,” I’d put them under the rail only if you can see the old adhesive rectangle on the underside of the rail itself. That’s the best real-world proof. If the underside of your rail has a clean rectangular witness area where something used to be stuck, that’s your location. If there’s no witness mark under the rail but there are obvious adhesive remnants inside the cassette at a contact point that isn’t part of the greased cable groove, then they may be anti-rattle pads in that area instead.
If you want to settle it quickly, post one clear photo of the underside of the left and right rail/carrier pieces on the bench. If I can see the old glue outline, I can tell you immediately whether those 1x8 strips are meant to go under the rail on your setup.
Also, since this is CarBot Corner, it’s fine to disagree with me, but let’s keep it practical: follow the witness marks and avoid putting felt anywhere it can get soaked with grease or dragged into the cable groove.
