Cooling fan issue
BennSport
Has thanked: 7 times
Been thanked: 30 times
Okay the thermoswitch is a little harder to access than I thought. I’ll check it later this week when I have the car jacked up to recharge the ac
‘83 Platinum N/A 944
walfreyydo
Has thanked: 32 times
Been thanked: 58 times
Check the fan relay first before doing the thermo switch. Its much easier to access and test.
You just unplug the connector that runs from the thermo switch to the relay, and then probe/jump the contacts in the relay connector to manually activate the high and low speed fans. If they work as intended when jumpered, then its likely the thermo temp switch. Again, outlined in Clarks.
Garage
BennSport
So jump terminals 85 and 86 on the fuse block correct? The Clark’s page doesn’t say anything about bypassing the relay to test
BennSport
Just tried removing the fan relay and I don’t have enough access. It’s so tucked away and the fuse block is too hung up for me to remove it to gain clearance. Aside from removing the bottom right screw and moving it past the hook are there any additional steps to removing the fuse block?
walfreyydo
Clarks says you should also be taking resistance readings (in addition to running 12v across 85 and 86) so would recommend following that procedure exactly.
I am only familiar with the later model cars, which you can test/jump the pins on the actual connector for the thermo fan switch which leads to the relay, while also having a more accessible fuse panel under the hood.
I dont know much about the early cars and how to remove the fan relay from the fuse block, unfortunately, so I dont have any tips for you. Maybe others will chime in with a good technique to removing that fan relay.
Garage
944er
Has thanked: 14 times
Been thanked: 59 times
Easy check if you have A/C. Turn on the A/C. If the fans both come on, it is the thermo switch in the radiator, or the wiring going to it.
BennSport
Yes, the fans do kick on when I turn the A/C on. I bypassed/jumped the thermofan switch, and everything seemed normal. 1 fan turned on in low speed while the car was turned off, and both fans kicked on in high speed with the car on. I went digging around a little and noticed the leak is actually coming from the thermoswitch. I’m planning on replacing the gasket and thinking I should just buy a new switch while I’m in there. I just don’t know what temperature variant to order with the thermostat I have in the car. I’m also thinking about replacing the radiator drain plug with the Lindsey racing radiator drain kit and was wondering if anyone has anything to say about it.
944er
So the thermoswitch is bad. Part number 823 959 481 F
icb
Has thanked: 59 times
Been thanked: 54 times
I purchased the remote drain a couple of years ago but haven't installed it yet, I'm waiting till I need to drain the cooling system again. I wrote about it here :
https://icb-machinations.blogspot.com/2 ... n.html?m=1
Ian Borg
1988 Porsche 944S
#19
Been thanked: 4079 times
I like having a drain valve in lieu of the blue plastic plug, but I made my own from McMaster parts. I didn't see any point in having a big floppy hose attached to the drain. Mine has a valve with barb on it, so when it's time to drain, I can slip a hose on the barb and open the valve. Seem tidier and less prone to inadvertent leaks that way...
#20
