Humidity Levels?
Has thanked: 255 times
Been thanked: 248 times
Amen! Salt is hygroscopic, and if not cleared regularly will gather humidity on its own if left in a space, even when there's otherwise non-condensing humidity.
I found myself in northern Ohio in the winter a decade or two ago, and marveled at the see-through doors where rust had completely removed the bottom skin and structure.
EuroFighter2003
Has thanked: 20 times
The 944 is definitely going to be properly garage stored over the winter months, I am lucky enough to have another car to tackle salted roads. It sounds like I might have another project to add to the ever expanding list...redo the insulation of my garage doors! Thanks all for the info.
Bearhawg
I can add a personal experience. When I purchased my 944 I was forced to store my ‘70 C10 truck in a non-climate controlled storage unit. I thought I was in good shape because it was well sealed and insulated and over the winter so lower humidity here in Georgia. After 30 days of storage I returned to find that any surface that was not sealed or painted was covered with “flash” rust. The master cylinder, calipers, fittings, unpainted areas of the engine block, you name it and it was covered. I was heartbroken to see what I had spent 3 years restoring go from nearly new to rust covered in only 30 days.
For me, the lesson was air circulation/exchange is just as important as temperature and humidity levels. Maybe more so. One gut wrenching lesson.
PSU_Crash
Has thanked: 191 times
Been thanked: 111 times
I run 2 dehumidifiers with auto set to 45 and 50% and a hose drain. Plus the Minisplit runs AC all day this time of year, which pulls a LOT of water out. This keeps levels under 55% no matter how nasty it is here in SE TN and it has been brutal this year.
Has thanked: 4461 times
Been thanked: 2422 times
PSU_Crash wrote: Mon Jul 07, 2025 4:23 pm I run 2 dehumidifiers with auto set to 45 and 50% and a hose drain. Plus the Minisplit runs AC all day this time of year, which pulls a LOT of water out. This keeps levels under 55% no matter how nasty it is here in SE TN and it has been brutal this year.
Same here for me in Mid TN! Two dehumidifiers plus the mini split keep my well-sealed and well-insulated garage in fine shape. I also run a couple of fans in the hot months, mainly overnight, to help circulate the air. All performs wonderfully!
Has thanked: 941 times
Been thanked: 4027 times
I struggled with heat (less so humidity) in my old garage, which has a split unit, but the garage was too big and drafty for it to really work as designed. The guy who spec'd that unit went by the book in terms of sizing and didn't really understand the unique needs of a drafty old garage. It was a constant struggle and one of the things I was determined to 'fix' in the new garage. The high ceiling added to the challenge, but our contractor 'got it' and fought fire with fire...
p.s., my nephew works for Milwaukee :)
PSU_Crash
blueline wrote: Mon Jul 07, 2025 4:43 pm Same here for me in Mid TN! Two dehumidifiers plus the mini split keep my well-sealed and well-insulated garage in fine shape. I also run a couple of fans in the hot months, mainly overnight, to help circulate the air. All performs wonderfully!
I also have a 14" louvered fan on a thermostat to pull hot air from the peak. My shop is 25x52' with 14ft peak metal building. It has been spray foam insulated and most walls finished in either metal roofing material or plywood. i didn't spray foam the ceiling because it had that reflective bubble stuff on it and I though, that's good enough for now. It is not. Plus the 4 roll up 10' doors with zero insulation. It can be tough to heat and cool, but the dedicated 6.4kW solar system with 200aH battery keep it running free of charge :)
PSU_Crash wrote: Thu Jul 10, 2025 7:45 am .... It can be tough to heat and cool, but the dedicated 6.4kW solar system with 200aH battery keep it running free of charge :)
A battery free of charge. I see what ya did there!
