928, 944, or 968? Which one to choose?
Has thanked: 277 times
Been thanked: 274 times
Spokayman wrote: Mon May 05, 2025 1:04 am <<...>
The 928 is a wonderful GT car, but it has the reputation of being much more maintenance and repair hungry than any of the other 4-cylinder transaxle cars.
This reputation is well-earned, unfortunately. But not because of the car itself, but mostly from deferred or missing or hobby-hack services. I suspect that many who purchased new didn't expect the car to need more than a new Malibu or Taurus at the time. Porsches seem to need a bit more than that, but when folks driving them had so much spare performance they didn't really notice the differences. Plus service wasn't cheap, and the not-dealer service support was focused on the 911 market. So cars were neglected, and when they stopped running they would be parked, or sold into a market that was tuned into the high costs of bringing a neglected example back to original glory.
The serious cost is almost always the restoration from neglected part. As far as regular costs of miles driven, for most it's still tires, brakes, and fuel. Again, this assumes DIY maintenance, but staying up on things that need service is consistent for any Porsche of any period.
The OP's original question assumes that the candidates are in similar condition, but doesn't state what that 'similar' condition is. If we are discussing neglected barn-find projects, the needle points easily to the 944 and maybe 968 solely because of the availability of donor cars and aftermarket pieces to bring it back to whatever the buyer has in mind as 'acceptable' condition. Meanwhile, as I casually scan the marketplace, there seems to be a larger number of 'just needs a few things' examples, and only a few 'needs nothing, everything works perfectly, add gas and go' offerings. And those 'works perfectly' cars can easily be several multiples of the cost of the ratty but runs driver. But still by far the best total value unless you have a relaxed expectation and a lot of DIY time and $$$ to contribute. An old cheap Porsche can easily be the most costly car you'll ever own.
A couple decades ago now at a cars & coffee in the L.A. basin, I met a 944 owner who loved his car but lusted after a 928. I knew an owner who had an excellent show-winning example available, so introduced them to arrange for the transfer. Five years of fun and driving later, the car was again offered for sale. The car had received no care beyond a few oil changes, and of course was no longer in top show-winning appearance condition either. It ended up selling for a fraction of the last sale price, and was replaced by a Honda Fit because it was cheap and came with a warranty. I've sold more than a few 'interesting' cars to folks who were seriously underprepared for the demands the car would make. Not big stuff, but the hour or two a few times a month with just cleaning and taking care of those little things that pop up. It got to a point where I refused to sell them to friends, only because the cars would wander back later with a request to make it like it was before. Neglect is like inflation and corrosion, a relentless curse that, once it's started, can be really hard and disproportionately costly to recover from.
Has thanked: 538 times
Been thanked: 279 times
Welcome to CARPOKES!
My first consideration would be why are you looking for these and what type of driving are you planning to do as the design parameters were different for a different focus usage when the cars were designed. 944 and 968 are smaller and a bit more nimble, 928 was clearly upscale on accouterments and more of a touring car.
As dr bob has pointed out cost is a factor, likely more so on the 928 as parts availability and service capability of available shops/specialists is a key consideration. These are all older cars and past history and care will vary wildly.
If you are just dipping your toe into the world of Porsche, want a more carefree usage with less concern on service and history and likely better parts and service, you might consider a Boxster as the volumes are higher, local service should be more available, and they will have more up to date A/T characteristics. If a convertible is a non starter, look at a Cayman.
walfreyydo's short-sweet-simple encapsulation says a lot with few words.
Horses for courses.......
Dkraven
Has thanked: 4 times
Been thanked: 8 times
Why is a manual not an option? Just curious. I taught one of my kids to drive manual in my 944, if in decent shape they're easy manuals to learn on.
jeff968
Been thanked: 4 times
To learn more about the 968s be sure to check out:
968register.org
zooklm1
Has thanked: 26 times
Been thanked: 62 times
A lot has already been said. I have not owned a 928 but have owned a 1988 924S Special Edition, 1986 951 and 1994 968 Cabriolet. I currently own both the 951 and 968. The 968 has the tiptronic. The nice thing about the tip is if you have to drive in a lot of traffic. The tip will let you manually shift where as the 944 auto won’t. I am working on a mod to use a 996 tip steering wheel to add shifting switches for manual shifting. In regular mode it starts in 2nd gear but you can put it into 3rd gear to force it into 1st gear. 2nd give a slow start but keeps you in the normal stop light traffic. On the highway and in spirited driving it works well. However, I still love the 951 and running thru the gears. The 951 has not been modified and is very easy to drive if you keep it in the power band as you work thru the gears. I mentioned the 924S because it is similarly powered as a base 944 and it was also a fun car to drive with the 5 speed trans. Given the power of the NA 944 (160 HP) I could not see driving it as an auto. Be sure to get maintenance records that show a recent replacement of the flex plate as that is a $1500 part plus $2000 labor to change.
Lee
Drscottsmith
Has thanked: 5 times
Been thanked: 16 times
Ditto everyone's comments above (all are a valid points even though some are contradictory - that is part of your decsion process).
My .02 to add - if you are going more for looks and not speed, get a NA944 versus a 16v or Turbo (especially). My 951 is just as difficult, if not more, than my 928 to work on in several areas around and under the car.
Parts are costly for any of these. The more work you can do yourself the lighter your pocketbook....but probably not by much.
Keep us posted!
