Oil pressure on rebuilt engine
michaelmount123
- Has thanked: 26 times
- Been thanked: 179 times
Removing the spark plugs is advisable when using the starter to get initial oil pressure. It not only allows the engine to spin faster by removing the compression load from each cylinder, it's also easier on the bearings prior to oil flow.
- Has thanked: 932 times
- Been thanked: 3991 times
It also creates a cool, but disconcerting, sewing machine sound.michaelmount123 wrote: Thu Nov 16, 2023 9:34 am Removing the spark plugs is advisable when using the starter to get initial oil pressure. It not only allows the engine to spin faster by removing the compression load from each cylinder, it's also easier on the bearings prior to oil flow.
